New 6x12 for Fishing Trips
Re: New 6x12 for Fishing Trips
Postby flboy » Wed Jul 21, 2021 10:19 pm
I used the 1/8 inch Luan plywood. Painted it white.
Sent from my SM-N970U using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Gonefishin » Thu Jul 22, 2021 3:50 pm
Following you closely. Really curious to see the A/C unit in, and out, and every which way. I'm going to try to put something in my 6X12 that is as simple as possible. "Portable," but not necessarily one of the "portable" units that are less efficient than window units. You sound like you might just have that.
Gonefishin
Images: 119
Postby Gulfcoast » Thu Jul 22, 2021 7:24 pm
I can't get any more simple than to slide my window unit out the cargo door that I installed.
6x12 cargo trailer - Mini Split A/C - Starlink - TMobile home internet
Gulfcoast
Postby Gulfcoast » Tue Aug 31, 2021 9:59 am
I don't want to cut any ribs to install a couple of windows to peek out.
What do you guys think about vertical windows ?
They will fit between the ribs, and slide vertically with screens on the bottom.
Gulfcoast
Postby nsfr1206 » Tue Aug 31, 2021 12:16 pm
I wonder how a camera system would work, with one mounted on each side of trailer and hooked to a monitor. Anybody done this?
nsfr1206
Postby onehoser » Tue Aug 31, 2021 4:06 pm
i put 2 door peep holes in the v of my 6x12 so that i could see if it’s a racoon or a bear rummaging around camp. i also have a wireless backup cam with infra red vision but i rarely use that
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby Gulfcoast » Tue Aug 31, 2021 4:31 pm
Gonefishin wrote:Following you closely. Really curious to see the A/C unit in, and out, and every which way. I'm going to try to put something in my 6X12 that is as simple as possible. "Portable," but not necessarily one of the "portable" units that are less efficient than window units. You sound like you might just have that.
I'll take some pics this week with my little A/C slid in the cargo hatch.
Gulfcoast
Postby Gulfcoast » Tue Aug 31, 2021 4:36 pm
I have 8 wifi camera's around my home and I'm not that impressed with them overall, I prefer wired camera's.
Gulfcoast
Postby Karebru » Tue Sep 07, 2021 4:18 pm
Gulfcoast wrote:I don't want to cut any ribs to install a couple of windows to peek out.
Rib spacing and seams in the outer skin determined everything when it came to tweaking my design as I went along.
I have a 14 x 21 vertical on each side towards the front, and think they work fine. It doesn't give a panoramic view but you can look out if you want to.
To us, camping is about BEING outside, anyway.
Having said that, I just ordered a pair of 14 x 16 verticals that I'm going to put towards the back, just to let a little more light in.
I'm not going outside until the temperature is above my age.
Karebru
Postby Gulfcoast » Sun Sep 26, 2021 12:50 pm
I'm just not in the mood right now to cut holes and install windows, so I bought three $2 peep holes and installed one in the door and one on each side of the trailer where the windows will go later. :D
Gulfcoast
Postby Gulfcoast » Sat Oct 09, 2021 3:18 pm
Just received two 16x14 windows for my trailer... any advice on measuring, marking, cutting and the installation with be greatly appreciated. These do have the trim ring on the inside.
Gulfcoast
Postby flboy » Sat Oct 09, 2021 4:28 pm
Gulfcoast wrote:Just received two 16x14 windows for my trailer... any advice on measuring, marking, cutting and the installation with be greatly appreciated. These do have the trim ring on the inside.
One thing I'd recommend if this is your first time... make a cutout template from cardboard and once you are satisfied the fit is right... use the template to transfer the cutting lines onto your trailer in the place the windows will go, then tape it off so the saw does not scrape the paint as you cut (assuming a jigsaw). It sounds , based on the size, that you will not be cutting any studs... so that makes it easier.... just make sure your template does not cover any studs, or you will have a surprise when you cut.
Measure a few times before you cut because recovery is hard if you make a hole too big.
I made a video when I put my windows in. Link to YouTube ==> https://youtu.be/R_TCqeIdL9Q There are some tips in there as well for cutting. Cut the corners last so you do not have a big piece of aluminum vibrating around as you are trying to cut the long spans.
Don (Flboy)
flboy
Images: 378
Postby Gulfcoast » Sat Oct 09, 2021 5:30 pm
One more thing.... will I be cutting through the aluminum, one inch polyiso and 3/8 plywood all at one time?
Gulfcoast
Postby hankaye » Sun Oct 10, 2021 7:32 am
Gulfcoast, Howdy;
Just look at the top subjects of this very forum. Second one is all about the window
install, and the questions folks have. Also includes the answers, even nifftier eh.
hank
hankaye
Postby Gulfcoast » Fri Oct 29, 2021 4:11 pm
Well after all the worry, the windows were pretty easy to install. The vented propane heater and vent is done and all I like for now is the fantastic fan on the roof. My wiring is complete with two new Lithium 100AH batteries. I'll try to take some pics tomorrow.
Gulfcoast
