saltydawg wrote:First for axle location we need pics or measurements.
DrewsBrews wrote:Beyond that there are aerodynamic issues the wider the trailer gets as it is not hiding as much behind the slip stream of the tow vehicle, adding extra MPG penalty which can really hurt on long trips. Then you have the additional light requirements, as noted previously, if the very outside dimensions are 80" or greater (including fenders, ect) but I doubt that is much of an obstacle.
DrewsBrews wrote:Going taller can probably hurt as much too. My build is going to have a 5ft tall cabin which puts the total height roughly 6.5ft on a trailer shaped like a brick. Current tow vehicle is a 5.4l f150 with open bed. Not looking forward to the MPG that combo will get...
Unless I get around to fixing my manual trans Saturn Vue that has had a replacement engine sitting next to it for a year and a half
DrewsBrews wrote:
A big reason for insulation in campers is moisture reduction. It is a small space and the human body expels alot of moisture. It will condense on the walls and floor typically overnight due to the temp difference. Not fun to wake up in being dripped on or in a soggy mattress. vent fans do help, though I imagine it is an uphill battle with no insulation. You obviously wouldn't need to go overboard on insulation due to your climate and comfort level, but some is helpful.
