kayakrguy wrote:Hello everyone,
I can't wait to get to the walls, which are my next step. I will get a new Jigsaw today, my old Craftsman 2.2 amp just isn't up to this job!
I need advice about Doors and hatch. I do not have a plunge router so I will have to jigsaw the door. I assume this means drilling a hole for the blade to start. Any suggestions about WHERE the hole should be relative to future construction issues--eg. tight seals etc??
Jim
Jim
Biggest and questionably the most dangerous mistake that I made was with the doors. I let myself get talked into "Square doors" because it would be easier to trim. Once I got them trimed up, it sure was easy but I had created a lethal campgroud weapon for middle of the night falls. The aluminum angle met at a perfect point that would split you open if you fell on it. I was like running with scissors, not a good idea.
Of course, the plus side was that if a bear attacked, all I had to do was open the door real fast and it would have gutted it. It also made cleaning fish super easy.
Needless to say, that was the final straw for me. When I do the trailer for two, I plan to use rounded doors.
