working on it wrote: I can no longer lift the 266 lb trailer tongue to shift position in the garage bay, nor can I swing it around outside to be able to use my front hitch, to store it in the garage bay. So, I figured that a 500 lb limit, industrial swivel caster would work fine, when mounted to my current jack's sand foot.
For $20, and an hour of my time (looking for some locknuts, mostly), I now can move it around OK. The eight inch diameter wheel rolls easily on my mixed surface driveway, and also raises the tongue high enough to easily hook-up to my tall hitch. Win-win.
Capebuild wrote:I see the benefit of having a front jack with a wheel (being able to roll the trailer around easily), but I'm wondering what the advantages are of the jack having a flat plate (rather than the wheel). Is it mainly for stability?
Thanks
John
Socal Tom wrote:I took a 4 INCH caster wheel with a brake, and mounted it to the flat plat ( bolted through some holes). It rolls much better than the standard wheels and the brake holds on flatish ground ( till I chock the wheels).
tony.latham wrote:Getting thirteen-hundred pounds to move isn't easy.
