bdosborn wrote:I'd be interested in seeing that build.
P.S. I need to start a build thread for our van...
I dunno if I'd do it here or over on the Transit Form. I like it here but there's more participation over there.
I was wondering if you had decided to switch to a van. I remember your questions earlyer in this thread.
The problem I have seen on other forum is the build way to heavy crowd. That group also seem to be narrow minded and don't take well to new construction ideas/ styles. This site seems to be more open minded and very willing to talk a person threw any problems a member asks about.
To give you an example I joined a bus conversion forum. After reading quite a few build threads. Most of members were using screws to install the ceilings. This was into wood blocking used as a thermal break between the body framework and living space. I made a thread and asked one question. Why is everyone using screws for ceiling install instead for a small brad nailer. I had one answer. That was from a member that wondered the same thing. I decided not to ask why everyone was using 2x4's and 3/4" plywood as their main lumber choices.
