New Build - 6*12 Offroad Toy Hauler
Re: New Build - 6*12 Offroad Toy Hauler
Postby flboy » Thu Dec 30, 2021 5:53 pm
I have to get all the hangers in place and ensure everything is tight and the muffler weep hole is the low point, but this is essentially how it appears underneath the CTC with the intake and exhaust.
Sent from my SM-N970U using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Thu Dec 30, 2021 5:58 pm
featherliteCT1 wrote:I like your new fuel line connector. I had no idea that you could just friction fit a connector into the hole of the tank, held in place by the rubber grommet, with no nut inside the tank.
Thanks. It seems to be sealed well and it has the screen and etc. along with the shutoff. I needed the larger inside diameter of the nipple also.
I think it is going to work fine. These are sold as replacements for small gas engine tanks which are generally plastic. This must be how they are fitted.
Don (Flboy)
flboy
Images: 378
Postby flboy » Fri Dec 31, 2021 11:56 am
Have the box screwed down a sealed. Installed latches to hold lid tight against seal. Trying to ensure there will be no Carbon Monoxide (C0 ) seeping back in.
I did buy a Kidde C0 sensor/alarm to mount on wall right above where my head will be when I sleep. I am always a bit cautious about going to sleep in a small area with a combustion furnace. Should not be an issue, but we'll see.
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Fri Dec 31, 2021 12:10 pm
flboy wrote:Have the box screwed down a sealed. Installed latches to hold lid tight against seal. Trying to ensure there will be no C02 seeping back in.
I did buy a Kidde C02 sensore/alarm to mount on wall right above where my head will be when I sleep. I am always a bit cautious about going to sleep in a small area with a combustion furnace. Should not be an issue, but we'll see.
I guess I thought you were putting the heater into the box,
BigDave_185
Postby flboy » Fri Dec 31, 2021 1:15 pm
No, trying to keep fuel pump and etc. out of the way. I did not see any good way to mount fuel pump and etc. at the required 30 degree angle without it all being exposed below. My frame is 3 inches and I have 2 inches of foam. It would have not been ideal.
I have all the exhaust and etc. secured. Now I just have to clean up the wiring and mount the controller.
Don (Flboy)
flboy
Images: 378
Postby flboy » Fri Dec 31, 2021 5:23 pm
Well, the diesel heater is installed. I installed the controller right over the back of the couch/bed. The internal thermistor for cabin temp is inside the controller, so I wanted it where I will sit. Since the display is in Celsius only, I made a little conversion table card from 45F to 75F so I can set the heater accordingly. It just slides in behind the display on the wall.
I learned how to program it and I optimized the burn for 2kw. It seems to cycle fine. Looking forward to testing it out in some cold weather. The camper is more for 4 seasons now.
I also installed the rails and cut the board for the bed extension. I have a pillow to throw on that and now my feet won't hang off..Also used as an end table. Heater is underneath. The board just slides off and stows next to the heater if I want to take it off.
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Fri Dec 31, 2021 10:14 pm
I would like to install one in my trailer
BigDave_185
Postby flboy » Sat Jan 01, 2022 12:34 am
I think you'd like it and you're running diesel anyhow, so you'd just have a spare can on board that you could use for heat or in a pinch if you run out of fuel in your truck.
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Sat Jan 01, 2022 10:22 am
flboy wrote:I think you'd like it and you're running diesel anyhow, so you'd just have a spare can on board that you could use for heat or in a pinch if you run out of fuel in your truck.
Iv actually been running the heater in the new fifthwheel all month lol I don’t have a logical reason why but…. I’d end up running the diesel heater also to keep the toys warm in the snow
BigDave_185
Postby flboy » Sat Jan 01, 2022 1:15 pm
Yes, this is going to happen today!
BTW.. Happy 2022 to all!
Don (Flboy)
flboy
Images: 378
Postby flboy » Sat Jan 01, 2022 1:31 pm
Committed now!
Don (Flboy)
flboy
Images: 378
Postby flboy » Sat Jan 01, 2022 4:47 pm
I like it!
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Sat Jan 01, 2022 6:11 pm
I think you ordered the wrong one
H&B Luxuries Durable Acrylic Dome Dog Window for Fence to View Outside for Satisfying Curious Pets FW058 https://www.amazon.com/dp/B07CXHR9X5/re ... Z5DV1PXY0P
BigDave_185
Postby nsfr1206 » Sat Jan 01, 2022 6:15 pm
BigDave_185 wrote:I think you ordered the wrong one
I definitely support changing it out for that
nsfr1206
Postby flboy » Sat Jan 01, 2022 6:19 pm
Lol! Didn't know that was a thing. Lexus would probably like it!
Don (Flboy)
flboy
Images: 378
