Do you have an example?Gulfcoast wrote:You could use that, but I would use an automatic 12-volt battery charger.
Powermax 110 Volt to 12 Volt DC Power Supply Converter Charger for Rv Pm3-55 (55 Amp)
So you just cut the clamps off and crimp on a ring terminal?tony.latham wrote:Powermax 110 Volt to 12 Volt DC Power Supply Converter Charger for Rv Pm3-55 (55 Amp)
That thing looks like a monster. Get a Noco smart charger.
This charger supposedly works with lithium too right?Gulfcoast wrote:My 10-amp charges my sealed battery well, and then it throttles down to trickle charge automatically. I don't need anything larger for my use. But, my lithium charger has more charging amps.
Thanks! How far apart are your nailers at roof? I’m a little worried about sag with mine being around 24”. I wish I had ordered it at 16”.foxontherun wrote:I ran 4'x8' 1/4" Birch Plywood down the center of the trailer lengthwise (nose to ramp) instead of across (side to side). There is one seam in the middle that I covered with a nice piece of trim. You can sort of see it in picture where the cabinet on left comes out into the cabin. I did it this way to avoid lots of seams; my upper cabinets will cover the rest of the ceiling on the sides (plan to make them at least 16" deep). Trailer is 7 feet wide and my box is only 16 foot. The rest of my length is in the v-nose which the roof slopes down and there will be bathroom door where the roof seam would be.
Just a thought; have fun with it.![]()
Harry
