rjgimp wrote:MickinOz wrote:...but I can't help building for nuclear Armageddon proof.
Is this a really wise guy or just a wiseguy? Some days it's hard to tell.![]()
Is one a smart bastard or a smart arse? One doesn't always know for sure oneself.
edgeau wrote:Number 2 is looking good. Will you want to part with it? Might be number 1 that gets sold?
Staryder61 wrote:MickinOz wrote:One supposes one opens oneself to accusations of bias, but one does feel that one's first attempt at homemade doors came out alright.
And the One that supposes the accusations of bias, should and can own that. Those doors are amazing.![]()
Everything about them looks right.
MickinOz wrote:It was fingers crossed all the way, but it worked.
There is no rubber seal. Edge says not needed, but I have a plan f I decide to fit a seal after all.
2mm thick self adhesive EDPM, 20mm wide, is not very expensive.
MickinOz wrote:So, I checked my measurements. The door jamb comes up 85mm from the floor.
The mattress is 150mm. So I have 65mm (2.5 inches) of mattress compression before the backs of my legs hit the door jamb.
Shouldn't be too uncomfortable.
I was aiming for about 70mm from the floor with 80mm from there to the top of the mattress, but I screwed up. I basically drew in the opening where I wanted the door jamb to land.
There is a cause of these little errors.
I really only draw a profile on graph paper and start marking an cutting, with occasional reference to the Benroy plans.
Professionals would run a lot more detailed plans, I think.
MickinOz wrote:My substitute reading lights turned up. They are fantastic. $17 a pair, and absolutely tiny.
No bigger than my thumb. Very bright. I measure the current draw at ~80 mA for one.
