New Build - 6*12 Offroad Toy Hauler
Re: New Build - 6*12 Offroad Toy Hauler
Postby BigDave_185 » Sun Jan 30, 2022 10:13 am
Makes me wonder if some motion sensor lights for dark areas off alone would be worth while?
Light up some real sq ftage. There could have been more folks just out of your site line.
BigDave_185
Postby flboy » Sun Jan 30, 2022 10:17 am
Yes, after this and for future solo boondocking, I am considering infrared cameras and then some type of floodlight on all 4 sides I can throw on if something is going on. Monitor will be on wall by where I sleep.
I have windows, but when it is pitch black outside, they don't help much. The infrared will help me see in the dark. They will be motion activated for anything roughly over 75lbs. Don't want to be alerted by small game and etc.
Also, if it is a person, I can let Lex out first to distract while I exit.
Sent from my SM-N970U using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Gulfcoast » Sun Jan 30, 2022 10:19 am
I bought these LED lights and my trailer is well lit outside at night. I've ordered camera's too.
https://www.amazon.com/gp/product/B07NQ ... UTF8&psc=1
6x12 cargo trailer - Mini Split A/C - Starlink
Gulfcoast
Postby hankaye » Sun Jan 30, 2022 11:58 am
flboy, Howdy;
Good to hear you got out of there in the same number of pieces as you went in with. ;)
For all the good folks you may encounter out there there are always a few of the not so nice ones.
Having a thinking security system is always a good thing to have along. Also provides the excuse that
you really aren't yackin' to yourself when you get questioning looks while you explain life's mysteries
to Miss Lexi.
Stay Safe,
hank
hankaye
Postby onehoser » Sun Jan 30, 2022 4:20 pm
night vision goggles might be more versatile, i’ve been looking at some on amazon
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby flboy » Tue Feb 01, 2022 8:18 pm
Night Vision goggles... That's a thought. ;-)
Was going to move towards the Grand Canyon, but weather is too cold there with lows in the teens all week. I think I'll stay here a few more days. I like it here and only into the mid 30s and low 40s at night. Worried about tanks freezing.
Lexus is liking her freedom here in any case.
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Tue Feb 01, 2022 9:18 pm
How many miles ya clocked on the bike?
BigDave_185
Postby flboy » Wed Feb 02, 2022 1:49 am
BigDave_185 wrote:How many miles ya clocked on the bike?
A little over 200. I don't go out too long or too far as I have to keep my dog locked inside the CTC.
Don (Flboy)
flboy
Images: 378
Postby piperpilot3tk » Wed Feb 02, 2022 8:35 am
Have you considered enclosing the bottom side and heating that area so you can use the CTC in cold weather?
I am thinking about using coroplast to close in the belly on my next build. I have seen this type of material used on newer factory built campers. https://www.ebay.com/sch/i.html?_from=R ... t&_sacat=0
If the bottom side was sealed up well enough, it may be possible to duct some heat from a diesel heater below the floor and keep the tanks from freezing. It wouldn't cost much to install some thermocouples on the tanks and pipes to monitor the temperatures.
piperpilot3tk
Images: 29
Postby flboy » Wed Feb 02, 2022 11:48 am
I thought about it, but the gray water is not a big concern. I put a 60W heating pad under it for some freeze protection; however, it is just gray water and if I am boondocking, I'll let it run out as I use it.
My biggest concern is the 40 gallon fresh water tank in the back of the truck. I could empty it, but then I only have 15 gallons with me.
Aside from that, no point just sitting in trailer all day if it is too cold to be outside. At least if that is going to be the norm. I also didn't bring alot of cold weather gear. I am from Florida and just don't have it.
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Wed Feb 02, 2022 12:56 pm
Cold weather gear? You mean ride harder? Lol jk
I can’t count how many Hoodies I have abandoned in a tree after a cold weather start and thinkin all grab it on my way back lol
BigDave_185
Postby hankaye » Wed Feb 02, 2022 8:03 pm
flboy, Howdy;
You mentioned; " My biggest concern is the 40 gallon fresh water tank in the back of the truck. I could empty it,
but then I only have 15 gallons with me. "
Don't keep it full, just keep level at 3/4 to 7/8's full. Leaving room for expansion. You can also use your 60wattt
heater and either lay it over the tank and some reflectix to help hold the heat in. Orr, put some plywood under the
tank with the heat pad between the 2. Lots of ways to go about it, just need to open your mind..... :thinking:
hank
hankaye
Postby Gulfcoast » Thu Feb 03, 2022 9:04 am
I need a side mount omni cell antenna for my trailer. Ideas? Thanks
Gulfcoast
Postby flboy » Thu Feb 03, 2022 12:13 pm
Gulfcoast wrote:I need a side mount omni cell antenna for my trailer. Ideas? Thanks
This is the antenna I bought. Seems to work well.
High Gain 10dBi SMA Male Wide Band 3G/4G LTE Omni-Directional Outdoor Fixed Mount Antenna for Mobile Cell Phone 4G LTE Router, Eifagur https://www.amazon.com/dp/B086YM8ZKL/re ... UTF8&psc=1
Don (Flboy)
flboy
Images: 378
Postby flboy » Thu Feb 03, 2022 12:19 pm
This little device that sets on top of the stove does a good job of warming up the CTC quick. I wouldn't use it and go to sleep or etc.. The diesel heater I have works for that. But I like to have a few options if one fails and it is good just to take the chill out of the air if needed.
Don (Flboy)
flboy
Images: 378
