My tow vehicle weight limit is 1500lbs.
tony.latham wrote:My tow vehicle weight limit is 1500lbs.
If you build something similar to the camper in the photo using traditional methods, it will more than likely weigh well over your 1500 pound max.
And by the way, because of the frontal mass of that design, it'll have a lot of drag. In other words, for a small car, it'll be a beast to tow at anything above 50.
I don't mean to be the bearer of bad news.
tony.latham wrote:.........And by the way, because of the frontal mass of that design, it'll have a lot of drag. In other words, for a small car, it'll be a beast to tow at anything above 50.
Pmullen503 wrote:tony.latham wrote:.........And by the way, because of the frontal mass of that design, it'll have a lot of drag. In other words, for a small car, it'll be a beast to tow at anything above 50.
That's going to be like towing a parachute....
A vardo has the advantage of standing room, taller doors, etc. which makes it easier to reconfigure the inside for sleeping, eating, sitting and cooking. So, if you don't plan to move it very far or very often, the design has definite advantages.
is well worth the weight savings and lack of rot.
You May find a search for (Orange peel pipe cap) Handy for a shape like that.BrianInVA wrote:I just found a tutorial on making cone shapes with foam so the process to cut and glue the top semicircle at the top of the front end to meet the roof line looks fairly straightforward.
CRZ42 wrote:Keep keeping an eye on FB marketplace and craigslist and something will popup sooner or later.
Another possible source if you haven't already checked is building supply houses. The local one near me was $7 less a sheet but you had to buy 10 sheets minimum, at the tie I found this out, I only needed one sheet. But when I start my next build I will be going there.
Another option is talk to any contractors that you might have in your network. They may have leftover/partial sheets they can give you. I managed to get some chunks (under half sheets) that I could use for shelves or braces.
