swoody126 wrote:WHEN POP RIVETS POP the center comes out and the head doesn't always remain
this is an invitation to a leaky installation IMHO
Riv-Nuts can be used with rubber gaskets between the nut and the panel frame which woud be my choice
i admit having lusted for a Riv-Nut tool for over a year
sw
TimC wrote:Rivet nuts. They are pricier than rivets and require another specialized tool to install but sounds like what you are looking for.
MickinOz wrote:swoody126 wrote:WHEN POP RIVETS POP the center comes out and the head doesn't always remain
sw
I'd probably use the rivnut, but I don't think I'd use a rubber gasket, I think it'd be destroyed when it is pulled down. I 'd probably put a sparing wipe of good quality silicon sealer around the flange before insertion.
But one thing to be borne in mind, I reckon.
Rivnuts or pop rivets, it's only going to be as strong as the sheet metal it is rivetted to.
TimC wrote:If you only have a small number to install it is possible to "set" them with a bolt (grade 5 or 8 preferably) and a socket & ratchet. The rivnut tool would be preferred but ive seen people use a torque wrench to assure proper setting and it has worked. I like Mick's suggestion of silicone seal rather than a rubber washer.
swoody126 wrote:my reference to a rubber gasket was not under the head of the Riv-Nut it is to go between the Riv-Nut head and the solar panel frame
rubber gaskets/washers can be had in various diameters and can be sized to cover the head
sw
sw
Philip wrote:Buy a riv-nut tool and don't look back. When I bought my tool they were expensive. After a few decades of use I think its payed for itself. Setting them by hand can be a challenge. It can be done but there is a learning curve to overcome. I have done it both ways. Thats why I bought the tool. Thye tool is faster.
With a setting tool the learning curve is just don't over set it. You know when that happens. You pull the threads out of the nut.![]()
BTDT
Philip wrote:Most riv-nuts don't take as much pressure to set them as you think. It's about the same pressure as a pop rivet. My tool is the pop revit style tool.
I am sure there are websites that have done reviews on rev-nut tools. Use that as a starting point. Then look over the types of rev-nuts on the market. There are a few different styles. Pick the style that you think fits your build best.
