Banging roof and wall panels
Re: Banging roof and wall panels
Postby astroinfidel » Thu Feb 17, 2022 9:58 pm
Thanks to all for the advice about the banging panels. Some say that putting a polystyrene type of panel in place stopped it, and others say it did not. Spray foam sounds like the solution for the small gap between the panels and the roof, but using the proper amount seems tricky. I have some left over pink fiberglass insulation that I am considering using. It is a one piece metal roof so a leak is not very likely and it should stay dry. I will be using some kind of vapor barrier on the roof so interior moisture shouldn't be an issue. I still have a while before I take the trailer back to Canada and can do the insulating. Thanks again!
Dean
astroinfidel
Postby BuildingOurDayDream » Thu Feb 24, 2022 8:02 pm
Hmmm, sure glad I stumbled across this! I need to be on the lookout for this issue. At the moment I'm booked to have about a 1/4" gap between the insulation an the wall paneling. But I would hate for anything I squeeze into that gap to bulge out the non-rigid wall paneling I have planned....
BuildingOurDayDream
Users browsing this forum: Google [Bot] and 4 guests
