Is it time for new batteries?
Anything electric, AC or DC
Postby Spotman » Sun Mar 13, 2022 1:16 pm
I have had two (2) Interstate deep cycle RV batteries in my teardrop for about 4-5 years now. I haven't really used them for the purposes ie; ceiling fan, several Led lights or usb/cig plugs. Most of the time always running off campground power. This Teardrop is always plugged in and garaged so the only time off power is traveling. I just recently installed a 100 watt solar panel and Renogy hook ups. Problem when testing outside in direct sunlight, just having fan on draws battery down within minutes! I have attached several pictures that were taken today in a 10 minute period. I need some expert experience advice. The pictures are in the steps on the Renogy control. The first picture is when plugged in. ImageImageImageImageImageImageImageImageImageImageImage
Sent from my SM-N950U using Tapatalk
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
Re: Is it time for new batteries?
Postby Spotman » Sun Mar 13, 2022 1:26 pm
Oh yeah, this is my Teardrop. Image
Spotman
Images: 241
Postby John61CT » Sun Mar 13, 2022 3:36 pm
Yes, the only way you get more than that from consumer grade batteries is meticulous care, which takes better gear as well as the knowledge.
Without those factors, even spending 5x more on top industrial deep cycling units is wasted
but put the two together, and you might get a dozen years.
All this assuming EoL replacement at 70-75% SoH.
Short answer yes, plan on replacing a House bank every 3-5 years, depending...
John61CT
Postby Tom&Shelly » Sun Mar 13, 2022 4:04 pm
Looks like you are going from 13.5 volts down to 12.8 volts in "minutes" once you switch on a load? That sounds normal to me. 12.8 volts is a good operating voltage for lead acid batteries.
How long does it stay at 12.8 volts? Your batteries may still be perfectly healthy.
Tom :thinking:
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby Spotman » Sun Mar 13, 2022 5:08 pm
Tom, tomorrow I will test it a little longer and plug in the 12 volt fridge and see if I can stay at a good level. Temps are down in the 40's right now.
Bob
Spotman
Images: 241
Postby tony.latham » Sun Mar 13, 2022 7:57 pm
The only way to use voltage as a measure of battery health is to give it 45 minutes or so at rest with zero consumption. It's called resting voltage.
:thinking:
I suspect you're okay.
Postby Spotman » Sun Mar 13, 2022 8:09 pm
Do you mean once you unplug from shore power wait about 45 minutes? Then check voltage and power up some things.
Spotman
Images: 241
Postby MtnDon » Sun Mar 13, 2022 8:29 pm
Disconnect the loads and the charging system. See what the volt is after an hour or so. Using a voltage reading shortly after discontinuing a charge or shortly after turning off a load can give false values. Too high or too low.
You don't say if the batteries you have are sealed or flooded types. If they have removable caps a hydrometer, with the proper electrolyte temperature correction applied is the absolute best method to determine the battery state of charge.
MtnDon
Images: 24
Postby edgeau » Sun Mar 13, 2022 9:42 pm
I have a similar Renogy charge controller. I can see you have it set for a sealed lead acid. I find the battery % is misleading while there is any charge or load current. As has already been mentioned leave it rest for a bit to get a reasonable reading.
Also I saw you were not getting much from the solar for full sun only .2 of an amp. Depending on the wattage of you panel you should be getting much more, eg my 200 watt will translate to 8 or 9 Amps on the controller in full sun. I even get 2 on heavy overcast days.
Sent from my Pixel 6 using Tapatalk
edgeau
Postby Spotman » Sun Mar 13, 2022 9:54 pm
My batteries. ImageImage
Spotman
Images: 241
Postby John61CT » Sun Mar 13, 2022 10:30 pm
Those are for Starter use only.
When you replace, go *or true deep cycling, 99% of the auto/ consumer market is fraudulently labeled.
Specify between GEL, AGM (sealed) or FLA which type you want. FLA best value - Ah per year - by far.
John61CT
Postby RJ Howell » Mon Mar 14, 2022 7:55 am
I do agree with the advise being given. Disconnect from source (s) and let it rest. I was taught that resting less than 12hrs is inconclusive results. Yet, if you do check in an hour and you dropped 12.8v to 11.8v, you know you have an issue. If you only drop 12.8v to 12.79v in that hour, inconclusive result.
With this in mind, plan to let it rest overnight before testing with a draw.
Maybe you stated it and I just missed it, but, what is the AH of the battery? I see it's a Group 27 so that could be anywhere from 50-100ah (C20 value).
RJ Howell
Images: 36
Postby mtbikernate » Mon Mar 14, 2022 8:38 am
When my AGM battery died, the voltage went absolutely nuts. It spiked and plummeted and back again within seconds. Damaged the control board on my MaxxFan in the process. I still wonder if my overhead light needs to be replaced because it occasionally behaves oddly ever since then.
I went LiFePO4 when I replaced the battery. I ran some numbers and found that it was at least as cost effective as AGM (11yr warranty on the LiFePO4 vs. 3yr actual lifespan on the AGM), and with more useable capacity per unit weight.
mtbikernate
Postby Tom&Shelly » Mon Mar 14, 2022 10:00 am
Spotman wrote:Tom, tomorrow I will test it a little longer and plug in the 12 volt fridge and see if I can stay at a good level. Temps are down in the 40's right now.
Bob
Hi Bob,
I suggest going ahead with what Tony and Don suggest. They know what they are talking about (Don has an off-grid cabin and uses batteries). Particularly, check the fluid levels in the cells and PH with a hygrometer.
after that, what you are suggesting--running the 12 volt fridge while monitoring the voltage from the battery--seems sound to me. After all, that's how you plan to use the battery. If the voltage doesn't drop down past 12 volts fairly quickly, I'd call it good.
Tom&Shelly
Images: 2282
Postby Spotman » Mon Mar 14, 2022 12:49 pm
Thanks for all the great advice. Been running Alpicool fridge couple of hours now at 12.8+. I'll see how it goes when sun decreases.
Spotman
Images: 241
Return to Electrical Secrets
