Sandwich/gelocat panels construction
Postby cineview » Mon Mar 21, 2022 3:53 am
Hi guys, im planning on building a larger model which is around 4m, and want to use sandwich panels with gelcoat skin in 36mm size.
Altough its alot more rigid than building in plywood, i assume i need some sort of safety cage to stiffen the entire rig properly on the chassis, but question is, how much and how strong do i need to build it?
Can i integrate alu bars in the sandwich panels, or do the panels have to be attach to a cage that is hard mounted to the chassis?
Anyone else here built their camper in sandwich panels that might share their experience on this?
Cheers :)
cineview
Re: Sandwich/gelocat panels construction
Postby QueticoBill » Mon Mar 21, 2022 6:11 am
Is 4 meters length? What is width and height? Are sandwich panels and gel coat foam with fibreglass skins? If so, I'd say no framing is necessary.
QB
QueticoBill
Images: 22
Postby cineview » Mon Mar 21, 2022 6:18 am
QueticoBill wrote:Is 4 meters length? What is width and height? Are sandwich panels and gel coat foam with fibreglass skins? If so, I'd say no framing is necessary.
Its 4,5m long, 2,2 wide and 2,3 tall.
Yes, foam core with fibreglass gelcoated skin on both sides.
So theres really no need for extra framing, just proper glueing?
cineview
Postby Pmullen503 » Mon Mar 21, 2022 6:50 am
Additional framing around doors, windows and hatches will make adding those things easier later. Same thing with interior walls or cabinetry. Just having something to screw into or clamp to makes assembly easier.
Pmullen503
Images: 67
Postby RJ Howell » Mon Mar 21, 2022 7:05 am
I did a foam/fiberglass on my truck (truck camper) and used a steel skeleton. Only reason for it is the overhang (loft) over the roof.
168576
Add elements as Pmullen recommends.
RJ Howell
Images: 36
Postby saywhatthat » Mon Mar 21, 2022 1:58 pm
the way we laid up or panels put them in a bowl shape underload surprisingly how strong that is .
was interior exterior bonding beam.
fiberglass to fiberglass that expands the same
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby cineview » Mon Mar 21, 2022 2:22 pm
RJ Howell wrote:I did a foam/fiberglass on my truck (truck camper) and used a steel skeleton. Only reason for it is the overhang (loft) over the roof.
168576
Do you remember how many bars you used, vertically and horizontally, and how much extra weight it added?
cineview
Postby QueticoBill » Mon Mar 21, 2022 5:40 pm
Yes if joints like ceiling and roof are fibreglass and epoxy inside and out. Blocking as pmullen points out.
QB
QueticoBill
Images: 22
Postby RJ Howell » Tue Mar 22, 2022 6:57 am
[/quote]
Do you remember how many bars you used, vertically and horizontally, and how much extra weight it added?[/quote]
168588
The build is here: https://www.tnttt.com/viewtopic.php?f=55&t=72408
Pictures come back on page 2...
The camper with frig, was 70lbs over the removed bed weight. I have the actual numbers somewhere...
RJ Howell
Images: 36
Postby cineview » Tue Mar 22, 2022 7:01 am
168588
The camper with frig, was 70lbs over the removed bed weight. I have the actual numbers somewhere...[/quote]
Brilliant, thank you!
cineview
