RV van conversion
RV van conversion
Postby Gator417 » Tue Apr 12, 2022 8:29 am
A couple years ago I purchased an Aerostar (E4WD) for a camper project. PO insulated it, installed some solar panels and an inverter and used it for camping until he blew a head gasket.
My plan was to fix it, tweak it a bit and do the same until it got smashed by a tree. From the doors forward is still fine but the cargo area got hit pretty bad.
I think maybe I can cut the rear out and convert it to a mini-RV. Has anybody here done this? I'm not even sure which area to look fo info about it.
Thank you,
Gator
"Aluminum skinning is to cover rotting prone crappy plywood"
linuxmanxxx
Gator417
Re: RV van conversion
Postby Philip » Tue Apr 12, 2022 12:39 pm
Posting a picture of what you have to start with will help with answers. Right now no one has suggestions without a picture.
Philip
Images: 323
Postby Ottsville » Tue Apr 12, 2022 12:48 pm
Can't remember of it was here or over at expedition portal, but yeah, others have done this
Ottsville
Postby twisted lines » Tue Apr 12, 2022 1:26 pm
Ottsville wrote:Can't remember of it was here or over at expedition portal, but yeah, others have done this
I have seen a 4x4 isuzu back halfed looked nice. can't find it now. ^
Racking up; And Rapin foam
twisted lines
Postby Gator417 » Wed Oct 12, 2022 4:18 am
Where would one find this "expedition portal"? Asking for a friend.
Gator
linuxmanxxx
Gator417
Postby GPW » Wed Oct 12, 2022 4:57 am
Something like this ???
van trailer .jpg (482.69 KiB) Viewed 405 times
Postby chopperwalker » Wed Oct 12, 2022 10:37 am
I think he means the opposite. That is the portion that got crushed. I guess I'm picturing starting with a "pickup truck" without a bed
chopperwalker
Postby GPW » Thu Oct 13, 2022 7:31 am
Still trying to envision that ??? :thinking:
Postby Philip » Thu Oct 13, 2022 10:10 am
I just looked up an aerostar van. That is a unibody vehicle. If you remove the crushed cargo section, you will need to make a structure strong enough to replace the loss of the original structure to keep it road worthy. The lower unibody will bend if no upper support structure is made.
You might be better off to find a box truck style chassis to start with. It doesn't need a massive structure to build off of. It has a frame to build off of.
Philip
Images: 323
