Has anyone made an egg trailer, like a Scamp?
Re: Has anyone made an egg trailer, like a Scamp?
Postby saywhatthat » Thu Mar 17, 2022 2:44 pm
If just pulling a few . look at Chesapeake Light Craft .look at the buck that used to hold everything together .If you use 3/8 hardboard and plasticine clay you would have a smooth outside surface do a shell then add foam then glass over .look at the trail top build . That a shell with right foam glue in. then glass a few layers over foam on inside
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby Frank R » Thu Mar 17, 2022 5:13 pm
saywhatthat wrote:If you use 3/8 hardboard and plasticine clay you would have a smooth outside surface do a shell then add foam then glass over.
Yep, that is one way I was thinking of doing it.
saywhatthat wrote:look at the trail top build . That a shell with right foam glue in. then glass a few layers over foam on inside
Do you have a link?
Frank R
Postby saywhatthat » Thu Mar 17, 2022 5:25 pm
if you use some like the buck not the trailer .trailer pod made from wood seems like an awful high price to pay especially with those doors and windows. by doing that with hardboard you've actually made of a mold
d
saywhatthat wrote:Do you have a link?
look at my signature.
saywhatthat
Images: 135
Postby Frank R » Thu Mar 17, 2022 6:16 pm
Frank R
Postby Pmullen503 » Thu Mar 17, 2022 7:11 pm
Frank R wrote:This is very promising and looks like it could scaled up:
https://thetinkersworkshop.blogspot.com/2015/03/teardrop-trailer-holy-grail-project.html
It would be easy to draw up plans, no real lofting required.
(Still like the boat tail with the matching bumper.)
Pmullen503
Images: 67
Postby Frank R » Thu Mar 17, 2022 7:44 pm
Here is a post on how he worked with a foam strong back and forms, and then covered them in strips. You can click the Newer Posts at the bottom of the page to see how this project progressed.
https://thetinkersworkshop.blogspot.com/2013/09/terratrike-velomobile-glued-trimmed-and.html
This guy is amazing. Look at all he accomplished.
Frank R
Postby saywhatthat » Thu Mar 17, 2022 7:54 pm
https://thetinkersworkshop.blogspot.com ... oject.html there's a way to make a buck for that probably take about a week in about 3 hr a day $ about 150 I sure like to see somebody get fiberglass trailer business going with reasonable prices. do the outer ring in plaster of Paris and then do an infill. doing the plaster like they used to do it in the old houses . When are we doing Trailtops trailers that's how we get a new profile for the outside ring
Picture 445.jpg (86.58 KiB) Viewed 558 times
saywhatthat
Images: 135
Postby Pmullen503 » Fri Mar 18, 2022 7:00 am
Frank R wrote:Here is a post on how he worked with a foam strong back and forms, and then covered them in strips. You can click the Newer Posts at the bottom of the page to see how this project progressed.
Lots of good ideas there. You could try out the techniques on something small first like a set of fenders or tongue box.
Pmullen503
Images: 67
Postby Frank R » Fri Mar 18, 2022 7:20 am
If I used 1/8" hardboard ($15 per sheet) for the smooth flat surfaces and only used foam for the rounded corners ($30 per 1"x4'x8' sheet), all supported by a flake board structure underneath, it would only require 17 sheets; around $500 for foam. Another four sheets of hardboard would cost $60. If I cut out the rounded corners on my CNC mill I could use maybe a third less sheets of foam.
This is for half-form only.
Here is a simple sketch. The angled sides look better but make the rounded corners more complicated.
168554
Frank R
Postby Frank R » Fri Mar 18, 2022 8:50 am
This is an excellent video to watch on how Scamps are built:
https://www.youtube.com/watch?v=9fnU-D2lWG0
Frank R
Postby Gator417 » Tue Apr 12, 2022 9:22 am
saywhatthat wrote:LOL
You need to do a hell of a lot more research they're made from polyester and chopper guns.
He only needs to make a mold if he's going to do multiple pieces. Sounds like this is a one-off so that's a lot of wasted time and money. It's not rocket science. Kids do this for science projects. I'm sure he can figure it out.
Gator
"Aluminum skinning is to cover rotting prone crappy plywood"
linuxmanxxx
Gator417
Postby saywhatthat » Tue Apr 12, 2022 8:37 pm
[quote]If just pulling a few [/quote ]
at one time that imply tooling
saywhatthat
Images: 135
Postby MickinOz » Wed Apr 13, 2022 5:05 pm
But you are quoting yourself, are you not?
I reckon it was one of your posts that said "if pulling a few." :thinking:
MickinOz
Postby friz » Wed Apr 13, 2022 7:13 pm
Frank R wrote:This is an excellent video to watch on how Scamps are built:
Osb for the floor seems to be a sketchy choice. Otherwise entertaining.
Sent from my SM-G965U using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Postby saywhatthat » Wed Apr 13, 2022 7:29 pm
MickinOz should been (Has anyone made a mold and glassed it? Links or pictures would be great.) are (Yes, I know their commercial molds are expensive. I know my mold will not be cheap.)
saywhatthat
Images: 135
