CapeBuild Build Journal
Re: CapeBuild Build Journal
Postby Onajourney » Tue May 10, 2022 3:24 pm
WOW! It is really looking spectacular. I hope you are doing what I am....throwing out all receipts. LOL
Onajourney
Images: 181
Postby Capebuild » Fri May 13, 2022 4:24 am
5.13.22
Onajourney wrote:WOW! It is really looking spectacular. I hope you are doing what I am....throwing out all receipts. LOL
Thanks! I don't throw out the receipts :cry:
Took a break from working on the doors and finished up the front bump out... installing the trim and black vinyl insert.
Will go back onto the pop open windows today.
John
FRONT 1.jpg (243.21 KiB) Viewed 1036 times
FRONT 2.jpg (218.51 KiB) Viewed 1036 times
Capebuild
Images: 130
Postby Capebuild » Sun May 15, 2022 10:14 am
5.5.22
A month or so ago in another thread I had posted a photo of an experiment to try and bend aluminum trim molding to finish off an indent I had created around where the axle was to go. If I had to do it all over again I would have not created that indent and just run the side board straight across. At any rate from that experimenting with a jig I made up I finally got to put it to the real test. Finishing up with the trim around the wheels will now let me install the fenders (some point soon).... but below are some photos of how the aluminum bending went.
John
indent bend 1.jpg (511.69 KiB) Viewed 1001 times
indent bend 2.jpg (515.03 KiB) Viewed 1001 times
indent bend 3.jpg (351.99 KiB) Viewed 1001 times
Capebuild
Images: 130
Postby Staryder61 » Sun May 15, 2022 11:05 am
John, that looks great. :thumbsup: Didn't expect anything less from you.
Was time consuming for you for sure. But the end product is well worth it. :applause:
I'm still waiting for the bending of the front window. ;)
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby S. Heisley » Sun May 15, 2022 6:05 pm
Your teardrop is really looking great! Love the shape and the attention to detail. You're going to enjoy this for years to come! :thumbsup:
Postby JasenC » Sun May 15, 2022 6:45 pm
Nicely done on the metal forming John :thumbsup:
JasenC
Images: 122
Postby featherliteCT1 » Sun May 15, 2022 9:16 pm
That metal bending jig may be the coolest and most innovative thing I have seen on this forum. Mucho Kudos!!!! :thumbsup:
featherliteCT1
Postby Capebuild » Wed May 18, 2022 5:37 am
5.18.21
Thank you Featherlite, Jasen, Sharon and Staryder for your comments. Bending that trim was not all that difficult. The difficult part was actually installing it and getting the driver drill into the small space in the axle area to drive the screws.
Some photos attached of the 2 pop open windows. They are fitted with bug screens. They will need some tweaking. The hole where the pusher post passes through is cut too low, making the fixed point where the post attaches to the window too low....... which is all causing the black part of the pusher post to rub on the bulb seal. Left this way that bulb seal will wear down and rip. I'll need to move the openings up about 1/8 inch.... but I'll save that for later.
Going to put the fenders on today and try and finish up the doors and get those installed (at some point soon). Then, just the big front window......
John
window exterior.jpg (426.99 KiB) Viewed 898 times
window interior.jpg (608.46 KiB) Viewed 898 times
Capebuild
Images: 130
Postby tony.latham » Wed May 18, 2022 9:51 am
Just... Your journal is like a well-written murder mystery. It leaves us on the edge.
Hey, great job on the windows. I'm impressed.
Postby OP827 » Wed May 18, 2022 10:31 am
The windows look exceptional! Did you make all that holding hardware yourself or purchased it?
OP827
Images: 414
Postby Capebuild » Wed May 18, 2022 4:51 pm
Capebuild wrote:. Just... Your journal is like a well-written murder mystery. It leaves us on the edge.
Thanks Tony! Building a teardrop is like a mystery to me :o
Every day something new and sometimes you don't quite know where it's going to lead you. "I think it was Professor Hex Bolt in the galley that caused that split.... hmmmm"..........But Thanks!!
OP827 wrote:Did you make all that holding hardware yourself or purchased it?
Thanks for your comments, OP827. The "window hardware" I made, molded the hinges in a hard (low durometer) urethane. The push posts I machined. If you are interested in the "molding process" I documented most of it in my build journal.... around page 14 it starts.
I don't usually tell stories on this site but I have one I'll share. I went to art school years ago and we had a painting teacher who taught this course "Oil Paints, Materials and Their Uses". The guy was about 100 years old, sort of bald with a long flowing white beard ... kind of looked like Mr. Natural....and dressed like a pile of undone laundry. He would tell us be careful when using the oil paint color Prussian Blue. It was such a potent and kind of acidic color. It gets everywhere. He went on to emphasize its transference possibilities like if you got a drop on your clothes and then get on the bus, before you know it everyone on the bus would have a touch of it on their clothes, face and hair.
WELL..... Proflex RV kind of reminds me of Prussian Blue. Whenever I'm working on the trailer, I'll be focussing on this small area for something..... and there it is, a schmere of Proflex!! How did it get there? There's no attached parts in the area, but there's that Proflex. It's everywhere. :(
I think I'll need to take a few days when the trailer reaches a certain point and just go around with a paint thinner soaked rag a do a bit of tidying up.
Anyway.... got one fender on today. I need to wait for more fender welting to show up. The stuff I ordered had enough to one fender but not two. My miscalculation.
IMG_6778 Medium.jpeg (137.61 KiB) Viewed 833 times
Capebuild
Images: 130
Postby S. Heisley » Wed May 18, 2022 4:54 pm
Wow! :o
Postby KCStudly » Wed May 18, 2022 7:04 pm
"She's a poser!" And that in no way is meant in a derogatory sense.
Back in the day when my buddies and I would shine up our hot rods and go to the cruise-ins we'd be proud of our efforts and earnestly make the same claim. "She's a poser!" :thumbsup:
Postby Capebuild » Fri May 20, 2022 6:53 pm
5.20.22
Thanks KC and Sharon. (I think I know what a poser is :)..... or at least I should).....but thank you again.
Got one door installed today. I had forgotten I added some wood backing in the interior in back of where the hinge's screws would wind up, to add more meat to hold the screws. And.... at last minute I moved the top hinge (off plan) making it lower.... so forgetting about that extra meat, missed the mark on the one. Moved the bottom hinge up a bit,(also off plan).... so missed the "meat area" there, as well. duh......
Also got some reflectors installed. That was fun.
John
Capebuild
Images: 130
Postby Shadow Catcher » Fri May 20, 2022 7:26 pm
Impressive build and attention to detail.
