Exterior lights... Switch????
Anything electric, AC or DC
Postby TallGuy7 » Fri May 20, 2022 2:50 pm
For the past few weeks I've been foraging parts for the teardrop. The living room now resembles a camping store.
The only thing I continue to struggle with is the exterior lighting. What kind of lamp is not the problem, but how do you switch this lamp on and off? All other lighting is either touch switched, or the fixture is fitted with a switch.
An outdoor light with an integrated switch seems a logical choice to me. Because if you leave during the day and return in the darkness, opening the lock is easier with some light.
The problem is that I simply can't find a lamp with an integrated switch.
What other solutions are there that I haven't thought of yet?
Menno
TallGuy7
Images: 26
Re: Exterior lights... Switch????
Postby saywhatthat » Fri May 20, 2022 3:57 pm
solar powered security lights .you can add a switch between the battery pack and the lights turn off when you don't want it to work
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby dchurch » Fri May 20, 2022 5:34 pm
Is this what you are looking for?
https://amzn.to/3GdkEqg
dchurch
Postby halfdome, Danny » Fri May 20, 2022 5:35 pm
With considerable searching I found small round LED light switches that I drilled holes in my plastic chrome plated porch lights to attach.
When wiring, I had the option to have a blue halo around the switch constantly on, or only when switched on.
I can find the light switch in the dark.
The same style of lights come in black & have built in switches.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Shadow Catcher » Fri May 20, 2022 7:30 pm
155985 the post had another purpose but you can see the 'porch light' with amber LED and lens. (less bugs).
Postby dchurch » Fri May 20, 2022 7:33 pm
Nice application Danny, I've used those switches for other projects.
Here's a link folks:
https://amzn.to/3G2IVPH
dchurch
Postby dchurch » Fri May 20, 2022 7:38 pm
Good idea Shadow!
If anyone is interested in colonrizing to prevent insects (or other reason) I put together a short video of a ridiculously easy solution.
dchurch
Postby TallGuy7 » Sat May 21, 2022 3:11 am
dchurch wrote:Is this what you are looking for?
Technically yes!
Aesthetically No!
This is what I was looking for. Unfortunately this item is discontinued.
Verzonden vanaf mijn iPhone met Tapatalk
TallGuy7
Images: 26
Postby dchurch » Sat May 21, 2022 8:46 am
Gotcha, I miss understood the original post. Here's a similar fixture to install a switch into. Aside from the flush illuminated switch there are waterproof rockers and toggle switches. Mouser .com has a good selection.
I did find the style of fixture you referenced here-->
https://amzn.to/3LDRhOK
dchurch
Postby TallGuy7 » Sat May 21, 2022 6:18 pm
Well.... My girl said that those would be great in black.... I stand corrected.
Luckily I found them in black on Amazon.com and ordered them right away.
Funny thing is that on the Dutch site of Amazon you cannot buy these.
Problem solved! Thanx!
Menno
TallGuy7
Images: 26
Postby friz » Sat May 21, 2022 6:31 pm
My outdoor light is a fire or a citronella candle. Too many bugs here.
Sent from my SM-G965U using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Postby tony.latham » Sat May 21, 2022 6:58 pm
I find these damn handy at zero-dark-thirty in big bear country.
:frightened:
Postby TallGuy7 » Sat May 21, 2022 7:25 pm
This is what we are planning for:
When the weather is bad we will go where the weather is good! All bad: we are going home.
TallGuy7
Images: 26
Postby gudmund » Sat May 21, 2022 11:32 pm
I second Tony's "damn handy at zero-dark-thirty" idea for the flash-lite holders - but - being I am 'not' of the 'qualified' wood worker class of the human race (have missing part of right thumb/table saw accident proof of this - 50+ years ago) I, 'stealing' Tony's Book idea, changed it just a bit using a different mount and liked it so much!! that I now have 4 of them mounted in my trailer = two just inside the galley door (one right-one left) and the other two - just inside each side door attached to the overhead shelf (one right-one left also) any one of the 4 can be easily accessed from the outside for use at any time, along with the two mounted inside the side doors working also as overhead lites = any time needed when inside = just reaching up and pushing the on/off button. All 4 of them have Lithium rechargeable battery's which hold up great!! (much better than the AAA's did!!! ) :thumbsup: 169228162441
gudmund
Images: 39
Postby bdosborn » Sun May 22, 2022 9:41 am
I carry the switch for the exterior lights in my pocket:
12v Wireless Relay
Images: 806
Return to Electrical Secrets
