CapeBuild Build Journal
Re: CapeBuild Build Journal
Postby noseoil » Sat May 21, 2022 8:42 am
John, this is beautiful, can't wait to see it rolling!
137905
noseoil
Images: 670
Postby Capebuild » Tue May 24, 2022 8:26 pm
5.24.22
Tim (Noseoil) and Shadow Catcher, thanks so much for your nice comments. Appreciate hearing that!
WELL.... BIG DAY TODAY!!
Fired up the grill-oven and tackled the front window. Picts attached. I found the form (the buck) had been affected by
the moisture sitting in the garage since I had built it in February. There was a bunch of unevenness. Went back to belt sanding some high spots and then covered the whole thing in aluminum to kind of even everything out. The oven worked well. Probably could have left the acrylic in the oven a bit longer...
the heat could have been a bit more evenly distributed. We (my wife and I) turned the acrylic once in the oven 180° to try and get the heat to affect all the surfaces evenly.....
but worked well. The hardest part was trimming the acrylic to be the correct size to fit the gasket. Put it in place and pulled it out 3 or 4 times, removing a bit of material each time.
I certainly didn't want to trim it too small. It still seemed to be oversized a bit.... but went ahead and imbedded the locking gasket and all kind of snapped into place. Satisfaction! :)
Very happy to have this part done.
John
acrylic rough.jpg (525.96 KiB) Viewed 825 times
window installed-5.24.22.jpg (532.01 KiB) Viewed 825 times
Capebuild
Images: 130
Postby JasenC » Tue May 24, 2022 8:31 pm
The window looks awesome John.
JasenC
Images: 122
Postby Staryder61 » Tue May 24, 2022 8:53 pm
John, absolutely beautiful job on your teardrop.. and that front window is just unbelievable.. :applause: :thumbsup: :applause: :thumbsup:
The time and workmanship that you have put into this build set a new standard of building teardrops on this forum..
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby lfhoward » Tue May 24, 2022 10:15 pm
That curved window is so awesome!!! I have never seen it done like this, but you did it. Congratulations John!
lfhoward
Postby Tom&Shelly » Tue May 24, 2022 11:14 pm
Great job John! :thumbsup:
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby Capebuild » Wed May 25, 2022 5:02 am
Thanks so much for the encouraging comments, Jasen, Tom, Lauren and David. Nice and I appreciate them.
That window was a big challenge and ever since designing the trailer that was really my main concern on how to do it.
So really glad to now have that in the rear view mirror. Now I need to figure out what to do with that grill-oven. If anyone wants to
bend some acrylic, it's yours.
I think I'm at the point where I can call the state police and apply for a VIN#. And get insurance..... and look to register it.
It's been just about a year since I started the building part..... almost done! (or as is said, "campable")..........
Thanks again!!
John
Capebuild
Images: 130
Postby Capebuild » Thu May 26, 2022 12:51 pm
5.26.22
This morning hitched up the trailer and took it out on the road for its maiden voyage to the town dump where they have a scale. First weighed the car and the trailer and then just the car and subtracted the difference. Trailer (dry weight plus the Dometic fridge) came in at 1,760 pounds. So a little over than what I would have liked (was hoping for 1600 #s). So be it. When we returned I weighed the tongue weight and that came in at 207 pounds. So around 12% of the total dry weight. I figure with our bikes on the back and the future tongue box of some sort loaded with all its stuff.... we should be okay, weight wise.
Drove nice and nice to have brakes on the trailer.
John
IMG_6847 Medium.jpeg (133.59 KiB) Viewed 721 times
Capebuild
Images: 130
Postby Staryder61 » Thu May 26, 2022 2:39 pm
Capebuild wrote:5.26.22
John
John, great looking duo you have there. You'll be giving all kinds of tours, and the questions. Oh gheeeesh, Where'd you buy that? How did you do that? Do you make them to sell?
A work of art it definitely is.. You should do a book.. :thumbsup: :applause: :thumbsup: :applause:
Be safe always, David
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Postby Onajourney » Thu May 26, 2022 3:50 pm
WOW! Incredibly fantastic John!!!
Did you use the spacing guide from TrimLok for the acrylic cut size?
Have you water tested it?
Brother..You are done. Congratulations on an amazing build. You got to do a walk around video. As someone here said, you are going to get stopped everywhere you go with this and asked all kinds of questions.
Onajourney
Images: 181
Postby S. Heisley » Thu May 26, 2022 4:45 pm
:applause: CONGRATULATIONS! :applause: :P
It's beautiful and more than road-worthy!
Give yourself a well deserved pat on the back.
Postby GarthB » Thu May 26, 2022 5:07 pm
Every time I read one of your updates I feel the inspiration to start another build due to your many great ideas and excellent craftsmanship.
Excellent work John! I hope you have a great time making use of it this summer!
GarthB
Images: 212
Postby Capebuild » Thu May 26, 2022 6:53 pm
Geeezz.... thank you so much for your encouraging comments, David, Sharon, Onajourney and Garth. Very nice of you all to say this. Appreciated!!!
This forum has been so encouraging and helpful. I can't imagine taking on a project like this without the helpful sharing of experiences others have had building these trailers.
I've got a long punch list of areas I need to go back to and rethink, revise, fix and otherwise, make better. With that said, we are hoping to take the trailer out camping sometime soon. I've been talking with my insurance agent to get coverage and they start the ball rolling with application paperwork for the DMV as far as registration, VIN, title and all that good stuff.
Onajourney, I'm not sure of your question about Trimlok's "spacing guide". I installed the gasket and cut the acrylic to the size I measured it should be. I installed it ....and took it out,.... trimmed it a bit more and reinstalled .... repeating this a few times. Kind of 'gingerly' sneaking up on the finished size that I eventually settled on. Also, no, I have not yet water tested it. On my punch list are a bunch of seals I yet have to finalize. The hatch needs to be adjusted. I'm probably going to have to unscrew the hurricane hinge and put a shim under it (like maybe 1/8" to 3/16"). The hatch fits nice on the top of the curve but there's a bit of space between molding and seal as it works its way down to the bottom. I think a spacer at the hurricane hinge (raising the hatch up slightly) might solve this.
Garth, I remember the troubles you had with your finishing with the Monstaliner and I did appreciate your persistence with getting satisfaction and getting it work "right'...... so inspiration there. Thanks.
Thank you all again for the nice comments.
John
Capebuild
Images: 130
Postby Indiana Rambler » Fri May 27, 2022 7:53 am
Wow! That looks great! Bet you feel relieved that it’s ready to use very soon! You’ve put a lot of time, effort, and forward thinking in that camper! I’m in awe my friend! Great job! Looking forward to pics in the wild soon!
Indiana Rambler
Postby bdosborn » Fri May 27, 2022 8:15 am
Great job John! :thumbsup: :thumbsup:
Images: 806
