V-twin mini bike
Re: V-twin mini bike
Postby noseoil » Thu Apr 07, 2022 9:20 am
Made brackets for the swing arm, 1/4" plate with slotted holes. This will allow the chain's tension to be adjusted for slack as the chain stretches over time, the axle can be moved to the rear.
168817
137905
noseoil
Images: 670
Postby noseoil » Thu Apr 07, 2022 9:40 pm
Next will be the rear suspension. Working on it...
168821
137905
noseoil
Images: 670
Postby tony.latham » Fri Apr 08, 2022 9:15 am
That thing's amazing!
Postby featherliteCT1 » Fri Apr 08, 2022 6:50 pm
++++++ ten! :thumbsup:
featherliteCT1
Postby noseoil » Fri Apr 08, 2022 10:25 pm
Thanks guys, appreciate the comments. It's moving along still.
Long day, tried this first, much too soft & too much movement, tire hit the rear frame!
168822
Plan B, so... I cut it apart, drilled the swing arm & welded in sleeves (12mm X 15MM), then re-set the top hangers
168824
168823
137905
noseoil
Images: 670
Postby noseoil » Sun Apr 17, 2022 9:16 am
Made the bracket for the rear brake setup. Should work well enough.
168906
137905
noseoil
Images: 670
Postby noseoil » Fri Apr 29, 2022 9:04 am
Ended up making a stand for the build yesterday. I'd been working on a 3' tall welding table, but there are some things which need a different height. Got some 2x4's, a sheet of 1/2" CDX ($53.00 here, ouch) & a 2' x 7' sheet of 16 gauge steel for the deck. The size is 24" wide X 7' long X 20" tall. Makes working a bit easier, I can use a small wheeled stool to roll around to get to different stuff. Still lots to figure out & do...
168985
137905
noseoil
Images: 670
Postby featherliteCT1 » Fri Apr 29, 2022 7:19 pm
Your work is simply amazing to me! :applause:
featherliteCT1
Postby bdosborn » Sat Apr 30, 2022 10:25 am
Please post a video of the first start, I wanna hear that bad boy run! :thumbsup:
Images: 806
Postby noseoil » Sun May 01, 2022 9:04 am
Will do a video, but we're not there yet! New induction for the air filter move, the factory one is restricted & sits up a bit too high, so...
169015
137905
noseoil
Images: 670
Postby noseoil » Thu May 05, 2022 8:45 am
More stuff, foot pegs, throttle & tensioner are coming along.
169055
169054
169056
169057
137905
noseoil
Images: 670
Postby Wrecit » Tue May 17, 2022 9:21 pm
If after it's together you feel it needs a little more on the engine side hit me up and I can get you with some guys that go extreme on these engines. I use to race performance karts and some guys would use these engines and get 50-60hp plus on dyno before they would hit the track.
You hide your conversion and call it stealth. I put mine out in the open and give it a beer.
viewtopic.php?f=50&t=74635
Wrecit
Postby noseoil » Sat Jun 04, 2022 8:49 am
137905
noseoil
Images: 670
Postby tony.latham » Sat Jun 04, 2022 9:39 am
noseoil wrote:https://www.youtube.com/watch?v=RO-MAGi2wHM
Good grief, Tim! That's a beast.
Postby twisted lines » Sat Jun 04, 2022 10:17 am
Nothing Normal :thumbsup:
Racking up; And Rapin foam
twisted lines
Users browsing this forum: Bing [Bot] and 10 guests
