I have been designing my own Teardrop for some time now.
Right now the idea is to make the door frame using angle iron and the door itself from square tubing lined with plywood.
This is the current design.
Looking at it now I think I should have gone with a taller angle iron for the door frame to try to get it flush with the outer wall.
Something like this.
The disadvantage of the taller angle iron is having less room to move the door frame itself to get the correct distance between the door and the frame so the seal works properly.
I have never worked with PMF before. I would very much like to know if my design is utterly rubbish and it has to be reworked, any input is very much welcome.
