Need help with tail light wiring.
Anything electric, AC or DC
Re: Need help with tail light wiring.
Postby bobhenry » Tue Jun 21, 2022 11:09 am
As an ex Uhaul company store manager I will give you a little tip. Go in on your day off and reserve a u haul trailer and ask if they will pre-wire your truck for the tow. We really did not want to wire trucks on Saturday "HELL" day so it is welcomed. Tell them what you want as a setup 4 pin , 6 pin or 7 pin and this is a plug and play setup. You can adapt down to the 4 pin flat from the 2 larger ones. Often this is done a a courtesy for the cost of the parts only. (Some time a small fee) . In a day or two just cancel the reservation and you are wired at little cost. Total time in the bay should be about 12 minutes !
Postby JasenC » Tue Jun 21, 2022 9:26 pm
bobhenry wrote:As an ex Uhaul company store manager I will give you a little tip. Go in on your day off and reserve a u haul trailer and ask if they will pre-wire your truck for the tow. We really did not want to wire trucks on Saturday "HELL" day so it is welcomed. Tell them what you want as a setup 4 pin , 6 pin or 7 pin and this is a plug and play setup. You can adapt down to the 4 pin flat from the 2 larger ones. Often this is done a a courtesy for the cost of the parts only. (Some time a small fee) . In a day or two just cancel the reservation and you are wired at little cost. Total time in the bay should be about 12 minutes !
You are an evil wicked man :lol: :lol: :lol:
I will keep the tip for sure.
JasenC
Images: 122
Postby rjgimp » Tue Jun 21, 2022 11:23 pm
Yeah, Bob's been around the block a time or three. :twisted:
-Rob
rjgimp
Images: 7
Return to Electrical Secrets
