Yikes! Didn't expect it to drain that quickly. (Naturally I put the shore power charger back on immediately.)
Odd thing is that I have a Coulomb meter on there
https://www.amazon.com/gp/product/B07CTKYFTG/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
(the one many of us have been buying lately), and it still read 100%. My thinking is that there is something wrong with the battery (at this point) and it is discharging internally, so the meter doesn't see it. That would also explain the fast discharge. Left it on a solar charger all Winter, which I thought would be okay. Maybe I'm wrong about that?
Ideas?
Edited to add More data: It's a 100 Ah battery (Group 27 AGM). The 4 USB ports, solar charger (disconnected to a panel), coloumb meter, and anything else with lights and fan turned off draws about 80 mA, for a total after the time I had shore power disconnected of 11.5 Ah. So why isn't the coloumb meter reading ~88.5%?
After a few hours of charge (shore power) the voltage is back up over 13 volts. I'll keep charging until tomorrow morning, then check the voltage after sitting for an hour.
I'll also take the cover off (not a quick job) and see if I've got water and/or debris sitting on the battery discharging it. I may try a discharge test later to see if the battery is obviously weak.
The business of the meter showing 100% vice 88.5% is what's confusing me...
