Boodro wrote:On my door corners , I took a file & rounded off the corners with a few quick strokes. I have yet to have an incident. I made my doors for easy in & out, I liked the round doors too , but decided that funcinality far outweighed looks. Just me. Good luck .![]()
http://tnttt.com/album_ ... ic_id=1744[img]
http://tnttt.com/album_ ... ic_id=1742[img]
Not real clear ,but hope it helps.[/img]
kayakrguy wrote:Overall, I was quite pleased with the practice cuts, but would appreciate any advice about the breakthrough/splintering problem with the jig saw...
Jim
tonyj wrote:My life seems to be ruled by sixteenths! I'm either 1/16 too long or short, tall or wide, thick or thin. Who invented them damn sixteenths?!
...we had built our doors with a 1/4 gap using the same considerations that you did...when we did the dry fit we found that we needed 5/16 to keep from having clearance problems.
madjack wrote:JP, hit the quote button at the top of the post you wish to quote from...the software will do the typing for you...alott easier than doing it yourself...you can also delete or highlight those portions you wish...try it, you'll like it![]()
That aside, how do you get a reliable, uniform 5/16 inch cut after the intial cut for the door?
