Jack swivel wheel just will not swivel
Postby davidreidok » Tue Jul 05, 2022 11:19 am
when I have my teardrop (little guy 5 wide) parked in the drive way, I cannot get the swivel wheel to swivel at all. It just seems to lock in place and will not rotate.
sprayed some lubricant spray in but no help
anyone know of a replacement swivel wheel with ball bearings inside or what am I doing wrong
much appreciated
dave
davidreidok
Re: Jack swivel wheel just will not swivel
Postby tony.latham » Tue Jul 05, 2022 4:13 pm
davidreidok wrote:when I have my teardrop (little guy 5 wide) parked in the drive way, I cannot get the swivel wheel to swivel at all. It just seems to lock in place and will not rotate.
much appreciated
dave
It may need a good cleaning. When your trailer is on the ball of your truck, how does it feel to manually swivel it around?
Postby Shadow Catcher » Tue Jul 05, 2022 6:34 pm
As Tony suggested git up of the ground run some cleaner and use a silicone lube (it does not attract dirt). Whack it with a rubber mallet to free it up if all else fails. :roll:
Postby JasenC » Tue Jul 05, 2022 6:41 pm
x2 on the silicone grease, you can get is at the auto parts store as well as the Borg stores. Just remember to shake it up like a can of spray paint.
JasenC
Images: 122
Postby davidreidok » Wed Jul 06, 2022 1:32 pm
Gentlemen,
Thanks for all the replies.
Next time I am at the hardware store I will get cleaner and silicon grease.
appreciate the feedback
dave
davidreidok
Postby Squigie » Wed Jul 06, 2022 2:43 pm
Does the jack have a swivel lock?
Squigie
Postby KCStudly » Thu Jul 07, 2022 11:54 am
I know with the jack wheel on my UT when the jack is retracted all the way up it ceases to swivel. If you haven't already, try extending the jack some.
Postby Modstock » Sun Jul 10, 2022 12:44 pm
KCStudly wrote:I know with the jack wheel on my UT when the jack is retracted all the way up it ceases to swivel. If you haven't already, try extending the jack some.
Mine does this also.
Sent from my SM-A115AP using Tapatalk
Modstock
