bdosborn wrote:lfhoward wrote:Bruce, just catching up and am super impressed with the Victron system you put together with a hot water heater and tank sensor!
Thanks! I just found a use for the Ruuvi wireless temperature sensor that I wasn't quite sure what to do with. I strapped it to the pressure relief valve of the water heater and insulated it with thinsulate. Now I can monitor the hot water temperature; it holds decent temperature overnight without having the heater being on.
I'm not impressed with the tank sensor, it varies wildly with temperature (50% over the day). I might need to insulate the sensor or something. I guess just being able to see some kind of level is nice. I didn't add or use any water today and you can see how the level varies:
But everything else has come together nicely.
lfhoward wrote:Mopeka (the maker of Bluetooth propane level sensors) and Victron are talking to each other.
lfhoward wrote:Did your battery incur any damage after charging at low temperatures?
