noseoil wrote:I would use cardboard panels & tape to fit the sides, top & bottom of each piece. Once the cabinet is assembled, trial fit to the structure, check for gaps, grind & fit again. Then, once it's a good fit, fasten it in place. It's a lot of work which requires some thinking & careful cutting & grinding, but it works well enough after a bit of practice.
bdosborn wrote: squeaks drive me absolutely crazy!
bdosborn wrote:Success! I got the fridge cabinet finished and installed. I think it looks pretty spiffy!
bdosborn wrote:Hopefully it will cool off a bit when you get back to it. It's been HOT here.
