Fishing pole storage / short bed truck
Postby Modstock » Fri Oct 07, 2022 7:31 pm
What are you guys doing for fishing pole storage in a short bed truck w/ shell ?
My new Lews rod is longer and it has to go diagonal across the bed.
Sent from my SM-A115AP using Tapatalk
Modstock
Re: Fishing pole storage / short bed truck
Postby Squigie » Fri Oct 07, 2022 7:41 pm
Two-piece rods, hang them out a window, strap them to the roof, zip-tie to a frame rail, or just leave them at home.
What I do on any given trip depends on what conditions I will be encountering, and how much I need a particular rod.
Squigie
Postby Tom&Shelly » Fri Oct 07, 2022 8:04 pm
Not a fisherman, so this may not be applicable, but back around 1947 one of the first fellows to build a teardrop had a cap on a piece of the metal tubing that ran the length of the trailer, and stored his poles in that.
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby RJ Howell » Sat Oct 08, 2022 8:16 am
Even some of my 2 pc rods don't fit!! I've slowly replaced my favorite longer types / styles with 3 & 4 piece rods. Thankfully 2 of my favorite fly rods fit (barely) in there case across the back of the truck!
So, I have:
2 Flyrods in their case (4 & 6 weight) two piece
1 3pc 9 weight in it's case
1 4 piece surf caster in it's case
1 spin caster 1 pc (shorty)
All fit across the cab just under the window. Bigger issue is how much space my associated gear takes up! :shock:
RJ Howell
Images: 36
Postby tony.latham » Sat Oct 08, 2022 9:55 am
I don't have any idea about dealing with a one-piece rod other than a rooftop rod holder. But they aren't cheap.
We carry our two-piece 9-footers broke in half in rod cases crosswise under our Tacoma's bed cap. The side window opens up and they're easy to grab.
Postby working on it » Sat Oct 08, 2022 10:08 am
Modstock wrote:What are you guys doing for fishing pole storage in a short bed truck w/ shell ?
* My short 4x8 trailer is comparable to a short bed camper shell in length; a storage tube (usually used by plumbers & electricians to store pipes or conduit) atop your shell would work. I bought a 10' long 6" diameter pvc pipe at Lowes, cut it down to 8' (all I needed) and installed a
Buyers Products CC600 PVC Conduit Carrier Kit, 6 Inch Diameter kit from Amazon. The kit consists of tube ends (one is lockable) and the clamping brackets (big U-bolts) needed to mount them on the vehicle. I could've gotten a 4" diameter or 8" diameter kit, but the 6" x 10' pvc was best for my purposes.
* See these two partial threads to see what I did: https://www.tnttt.com/viewtopic.php?f=32&t=70709&hilit=+fishing, and https://www.tnttt.com/viewtopic.php?f=2&t=70367&start=15*
enhanced 9-18-18 - Copy.jpg (211.7 KiB) Viewed 189 times
fishing gear tube on Amazon.JPG (44.59 KiB) Viewed 189 times
173193172890148599
working on it
Images: 457
Postby twisted lines » Sat Oct 08, 2022 11:17 am
Bazuka rod tube.
Racking up; And Rapin foam
twisted lines
