Re: Avanger Build
Postby bdosborn » Wed Sep 07, 2022 7:00 pm
Thanks!
Images: 806
Re: Avanger Build
Postby pchast » Wed Sep 07, 2022 8:38 pm
Nice work! :thumbsup:
pchast
Images: 97
Re: Avanger Build
Postby bdosborn » Wed Sep 07, 2022 8:42 pm
Thanks Pete!
Images: 806
Re: Avanger Build
Postby KCStudly » Thu Sep 08, 2022 2:58 pm
Nice work, as always!
The leather cabinet pulls are brilliant!
Re: Avanger Build
Postby JasenC » Thu Sep 08, 2022 6:04 pm
That is spiffelicious.
Leather pulls?
JasenC
Images: 122
Re: Avanger Build
Postby bdosborn » Thu Sep 08, 2022 7:04 pm
Thanks guys! Yeah, I saw leather pulls on a YouTube van build. I'm always snagging the pulls in the trailer (%$#@#%) so and I thought the leather pulls would be more Bruce-proof. :R
Images: 806
Re: Avanger Build
Postby nsfr1206 » Fri Sep 09, 2022 2:15 pm
That does look good. And I like the idea of leather pulls…
nsfr1206
Re: Avanger Build
Postby bdosborn » Sat Sep 10, 2022 5:01 pm
Thanks,
Images: 806
Re: Avanger Build Espar Heater
Postby bdosborn » Thu Oct 13, 2022 4:04 pm
Time to wake up the Espar diesel heater I've been hoarding for years. I've got one in the trailer and it's worked like a champ for years. The D1LC is getting pretty old, they haven't made it for awhile so parts are getting rare and expensive. My guess is this one is from around year 2000. Luckily I've been cherry picking eBay for years and have a few spare parts. I did a maintenance rebuild on this one, like the one I did on the trailer heater:
Espar Service
You get three tries to get these to run, after that they lock out and you need a special (very expensive) tool that I don't have to clear the error code. So if there's any problems with the fuel line, connections, etc, you have to figure them out quick. The end of the pickup fuel line was poking up above the level of the fuel, that's one failed start! Then, success!
Make sure and get the muffler if you get one of these, it makes a big difference:
Now I can drill a bunch of holes in the van floor to install it.
Images: 806
Re: Advanger Build
Postby featherliteCT1 » Thu Oct 13, 2022 7:10 pm
Heck yeah! :thumbsup:
featherliteCT1
Re: Advanger Build
Postby Philip » Fri Oct 14, 2022 2:43 pm
I hope that might not be to big of a heater. I use a 1400 BTU electric heater. Down to 30 degrees it works very well. It can hold 70 with no problem. That is with the upper vent open but not turned on.
Philip
Images: 323
Re: Advanger Build
Postby bdosborn » Fri Oct 14, 2022 6:29 pm
I have the same heater in the trailer, which is roughly the same size as the van and better insulted. Its been fine, the thermostat works well and throttles it down when it gets up to temperature. So I think it will work in the van. But you're right, it cranks out some serious heat. Overkill is the thrill I always say. :lol:
Images: 806
Re: Avanger Build
Postby Staryder61 » Mon Oct 17, 2022 9:26 am
Still hangin' around watching ya.... :thinking:
Have been off a little while.. I like what ya been doing..
Think you'll be warm enough with that?
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Re: Avanger Build
Postby bdosborn » Mon Oct 17, 2022 9:36 am
Probably. I'm drilling the holes in the van this week so we'll find out. :thinking:
Images: 806
Postby bdosborn » Tue Oct 18, 2022 8:58 pm
Well I bit the bullet and drilled the holes in the floor of the van. I put the heater in front of the passenger side rear wheel house. I used a carbide tooth hole saw and it went through the floor very nicely. I cut the carpet back from around the heater, just in case the heater case gets hot:
The hot air will blow back through the garage and under the bed. It should rise up between the bed and the rear doors as there is a 12" gap there. It should keep the batteries and water nice and warm.
The cold air will be pulled from the floor by the sliding door. I need to figure out some kind of transfer fan to blow the hot air down from the ceiling to the floor. Our trailer heater air stratified wickedly until I added one. Tomorrow I need to paint the holes I drilled and hook up all the heater wires, exhaust/intake pipes. I haven't figured out where to put the diesel tank yet, still noodling on a few ideas.
Images: 806
