I have Glue question
Postby Onajourney » Fri Dec 02, 2022 10:26 am
Getting ready to closeup the inner hatch with BB. I would rather not use a permanent glue like PL3 that I have used on most everything else. Thought being, I will have tail light, overhead light, and speaker wiring inside that I may need to get to in the future. I was thinking about using a hot glue gun. Any other suggestions on a non-permanent glue or reason not to use the glue gun?
Thanks Chris
Onajourney
Images: 181
Re: I have Glue question
Postby philpom » Fri Dec 02, 2022 10:43 am
Maybe you can strategically locate a few access panels that use no glue and then go ahead and use a proper glue everywhere else?
philpom
Images: 121
Postby tony.latham » Fri Dec 02, 2022 10:52 am
I don't know how you would use hot glue on such a large panel? And if you needed to remove it, wouldn't you have to heat the hatch to remove it? As in over 300ºF?
I'd also be concerned about the integrity of the glue. I use the stuff from time to time--it does have its place but it's not like PL3 or TB2 for strength.
Me? I vote you do a forever-wiring job and use the PL3. :thinking:
Postby Pmullen503 » Fri Dec 02, 2022 11:08 am
Non-permanent glue = glue that will eventually fail.
You could attach you panel with screws. You'd want to do a very neat job of spacing your screws since they will show.
I'd do as bulletproof a job of wiring as I could, and/or use conduit and glue the panel in.
Pmullen503
Images: 67
Postby Onajourney » Fri Dec 02, 2022 12:07 pm
philpom wrote:Maybe you can strategically locate a few access panels that use no glue and then go ahead and use a proper glue everywhere else?
Not a bad idea. I am going to mock-up some paper/elmer's glue joint this evening for test.
Onajourney
Images: 181
Postby noseoil » Sat Dec 03, 2022 9:58 am
I did a removable inside liner on mine. Glad I did as there was a problem I had to work on, the wiring was open & exposed with the panel removed. The hatch has 2 speakers, the 3rd brake light, back-up lights, ground, dome light, etc. It was a PITA to work on, but better than butchering a finished panel & starting over...
160262
137905
noseoil
Images: 670
Postby Onajourney » Mon Dec 05, 2022 9:13 am
That's a great looking galley Noseoil. Is the headliner only held up from the fasteners around the perimeter? I don't see any other ones.
Onajourney
Images: 181
