Forget "flex" panels, for longevity...
Your book's been very helpful...
KCStudly wrote:The profile shape is pleasant. But is there enough headroom in the V-galley once the roof goes on? From here it looks like not having the roof on the model is giving a false sense of headroom. Would want you to get to full scale and find out it's a problem.
celadon wrote:KCStudly wrote:The profile shape is pleasant. But is there enough headroom in the V-galley once the roof goes on? From here it looks like not having the roof on the model is giving a false sense of headroom. Would want you to get to full scale and find out it's a problem.
Good question! There may not be standing room in there at all, since I'd like to keep it below 7 feet tall for garageability. We intend to cook outside unless the weather says otherwise; the standy/stoopy part is mostly for standing and changing, room to put shoes on, accessing the storage, and a place for dogs to go if they want to leave the bed. I suspect it'll feel somewhat like one of those fourish-person tents where your head brushes the roof if you leave the very middle. The highest point of the profile is at the transition to the v, which should be close to 6 feet tall. The point of the v is mocked up at 4 feet tall, which may end up too short, but I'd like to do it if it's at all reasonable.
There will be a lot of profile experimentation, I suspect, once we have the chassis together and a floor built out.
OP827 wrote: You certainly could make enough headroom with dropped floor, similar to Woody's trailer design. You could also consider lifting roof options at this conceptual phase of your design..
