After bolting in Timbren, Steel tubing walls bent
Postby cjb028 » Wed Dec 14, 2022 1:31 pm
Hi there. I am in the process of building a frame. Last night I installed the Timbren axless system (3500lbs) and used a torque wrench to tighten the bolts to 90 lb. ft. I just noticed this morning that the walls of the square tubing (11 GA (.120 wall)) bent in (displayed in pictures). I'm not really sure how to fix this or what I did wrong. Any help would be much appreciated. This is my first time posting, so hopefully the photos upload ok.
IMG_3737 A LOW.jpeg (828.96 KiB) Viewed 885 times
cjb028
Re: After bolting in Timbren, Steel tubing walls bent
Postby Ottsville » Wed Dec 14, 2022 2:13 pm
I can't imagine timbren suggests that as an acceptable size to bolt a 3500lb assembly to. Did a tech sheet/install sheet come with it? Consider adding something stronger to bolt your axles to. Care to share your frame design here?
Ottsville
Postby Onajourney » Wed Dec 14, 2022 2:58 pm
I can't believe 90lbs of torque would do that. Have you double checked the wrench and measured the thickness of steel? It does not look like 11 ga in the picture but it's hard to tell. Something is definitely off.
Onajourney
Images: 181
Postby cjb028 » Wed Dec 14, 2022 3:02 pm
sorry forgot to attach the manual page
Screen Shot 2022-12-14 at 12.02.07 PM.png (934.09 KiB) Viewed 862 times
cjb028
Postby cjb028 » Wed Dec 14, 2022 3:04 pm
Onajourney wrote:I can't believe 90lbs of torque would do that. Have you double checked the wrench and measured the thickness of steel? It does not look like 11 ga in the picture but it's hard to tell. Something is definitely off.
Yea, I too am wondering if it was the wrench. I checked multiple times while using it that it was set to the 90lbs. It was very hard to get each one to hit 90lbs. I will double check the steel thickness.
cjb028
Postby tony.latham » Wed Dec 14, 2022 3:20 pm
What size bolts? The holes look big.
To me, the obvious fix is to weld 1/4" strap over the damaged section. I might bolt the suspension in place and tack it in place before the final weld.
Postby cjb028 » Wed Dec 14, 2022 3:28 pm
tony.latham wrote:What size bolts? The holes look big.
Hey Tony, thanks of the reply. The bolts are 1/2''. By strap do you mean a 1/4'' steel plate (cut to size to fit on the tubing) or something else? I apologize, I am fairly new to this.
cjb028
Postby chopperwalker » Wed Dec 14, 2022 3:28 pm
Could the wrench units be lbs-in? So 90 would have been 12 times what you should have set them to?
chopperwalker
Postby Onajourney » Wed Dec 14, 2022 3:39 pm
chopperwalker wrote:Could the wrench units be lbs-in? So 90 would have been 12 times what you should have set them to?
He'd be one strong fella. I can barely tighten to 120 ft-lbs and most only go to 150. I'm betting it's not .12 tube.
Onajourney
Images: 181
Postby cjb028 » Wed Dec 14, 2022 3:46 pm
I just checked and it is .120" . Thinking ill go buy another torque wrench and compare how hard it is to get to 90 lbs (on a scrap piece) and compare it to the torque wrench I used.
cjb028
Postby twisted lines » Wed Dec 14, 2022 4:22 pm
First Picture shows a plate on both sides the bolt goes through.
Says one is not included :thinking:
90 lbs yes that will bend 1/8" with out spreading the load.
Racking up; And Rapin foam
twisted lines
Postby cjb028 » Wed Dec 14, 2022 5:04 pm
twisted lines wrote:First Picture shows a plate on both sides the bolt goes through.
you are right, that is totally what I missed, dang. thanks for the help.
cjb028
Postby cjb028 » Wed Dec 14, 2022 5:11 pm
you know, thinking back and looking at the manual again, my plan was to do the 2nd option that is displayed in the picture which is to use a 2x2 as a cross-member. Its confusing because in the picture of that method, they do not use an extension plate.
cjb028
Postby tony.latham » Wed Dec 14, 2022 5:26 pm
By strap do you mean a 1/4'' steel plate (cut to size to fit on the tubing) ...
Yep! :thumbs-up: You should be able to find 1/4" strap that is the correct width.
Postby cjb028 » Wed Dec 14, 2022 5:28 pm
Yep! :thumbs-up:
perfect, thank you.
btw, although I'm build a square drop, your book has been the #1 resource for information and I have learned so much from it. thank you!
cjb028
