I'm consolidating some cold weather battery posts here so you might have seen these already:
In anticipation of the cold weather coming through Denver I had planned on bringing my batteries in the garage. Most are only rated down to -20C, here's the specs for my CALB cells (-10F= -23C):
It occurred to me that I added a battery heater to the bottom of each cell when I built the system, I've just never used them. They are controlled via a relay in the Victron Cerbo GX to come on when the battery gets down to 34F and turn off when it's back up to 37F. I decided it was time to try them out.
I covered the batteries with an old moving blanket and we'll see how it works with the cold tonight!
Here's the results:
I turned the heaters on Wednesday the 22nd and turned them off when we got home today the 26th. The heaters kept the battery warm down to -8F in the van (it was -15F outside).
Running the heaters costs around 10% of my battery capacity per day (40 A-Hrs/day).
I turned on the shore power battery charger right when the cold wave hit on December 22 but it was running on battery power the 23, 24 and 25th. The PV panels will keep up with the usage if I'm parked in full sun and it's fairly sunny. I was parked at my brother-in-laws house for Christmas and his driveway gets full sun all day. Our driveway only gets full sun till noon or so this time of year. So I'm not comfortable leaving the battery heater on all the time without being plugged into shore power, but its pretty close.
Here's what I concluded from the tests:
- I'm glad I used the bee hive heaters, they don't get too hot. Some of those Amazon silicone heating pads get way too hot.
- I'm going to bump the on/off temperature up a degree for a little bit more of a safety margin.
- I'm going to ask my wife to make a battery cozy out of thinsulate, I bet that heaters will run less with the better insulation.
P.S. Just a final follow up on the battery cozy. The battery was at 50F 4pm yesterday after turning the heaters on and charging. This morning they are at 37F, the outside temperature is 25F and the heaters stayed off all night. The heaters had just turned on as I took the screenshot at 7am. Charging definitively heated the battery up; the cozy will have to come off in the summer.
