Am I right in assuming that the reason this method isn’t promoted here is related to the cost of the epoxy and not to how good an adhesive bond will be formed?
GPW wrote:"you can get a smooth finish with practice " ...![]()
Best try this on scraps first ...
kstills wrote:So a big question I have is whether or not I need to reinforce the stress points where I'll be putting hinges and struts. I see I can buy different gauge fiberglass which will create different levels of structural integrity, but I have zero practical knowledge of how this works long term with repetitive actions like opening and closing doors (drawers I think will be less stress overall). I could certainly integrate some ply into the foam, but obviously if that's not necessary I'd like to avoid it.
Pmullen503 wrote:kstills wrote:So a big question I have is whether or not I need to reinforce the stress points where I'll be putting hinges and struts. I see I can buy different gauge fiberglass which will create different levels of structural integrity, but I have zero practical knowledge of how this works long term with repetitive actions like opening and closing doors (drawers I think will be less stress overall). I could certainly integrate some ply into the foam, but obviously if that's not necessary I'd like to avoid it.
Just like with PMF you will have to incorporate something to hold fasteners. A strip of wood to hold hinges screws. If you have through fasteners, something like a dowel with a hole drilled through it so you can tighten a bolt without crushing the foam underneath.
Pmullen503 wrote:Inset plywood eventually telegraphs through. I put it down to different thermal expansion coefficients. Using splines like you show should eliminate that.
