bdosborn wrote:It will be interesting to see how it shows up in VRM, I haven't seen any systems with 2 shunts.
The temperature relay logic is not something I've looked into. I had to do some special coding to extract the temperature from the battery monitor and suspect that isn't part of the relay logic. At this point I don't have plans to make any changed there.
bdosborn wrote:Couldn't you stick a Ruuvi tag to the battery and use the Raspberry Pi GPIO pin to control the heaters? You can adjust the offset of the Ruuvi so it matches what the BMV712 temperature probe shows.
P.S. did you SSH in to the Pi install the Setup Helper?
bdosborn wrote:Good idea, let me know how it works.
lfhoward,
Victron SmartShunt 500 amp - to monitor AC IN on the VRM
featherliteCT1 wrote:Wow! Quite the upgrade.lfhoward,
Will you be monitoring "AC" with the shunt or is that a typo that should be "DC"?
featherliteCT1 wrote:Awesome! I love learning about all these Victron products. It is a steep learning curve for me. I very much appreciate everything you post. Thank you!
