Your life will be easier if you go with 3/4” insulation and you’ll never notice the difference.Number 42 wrote:I am in the design phase of a 5x10 front slope roof "squaredrop". The walls will be 1 1/2" thick with 1" pink foam with 1/4" Prefinished birch ply on the interior and 1/4" acx ply skinned with painted sheet aluminum on the outside. I will plane down fir 2x4s down to 1" and frame the walls with that. I am having a hard time finding the right combination of aluminum trim or extrusion profiles and hinges to trim out and seal 1 1/2" thick doors. I dont like the look of leaving the core of the wall exposed, so I want to cover the edges of the opening and the door covered with metal. I looked on the Vintage Tech website and it looks like his material is designed for 3/4" walls. Any ideas?
