Teardrop Repair
Teardrop Repair
Postby Katewels » Fri Jun 19, 2020 3:22 pm
Hi everyone, I have Signatour teardrop trailer. It started leaking shortly after I bought it. I didn’t realize it was leaking at first because the leak blended in with the wood. I thought I had sealed it but it started leaking again. So it has been leaking for a few years. I’m concerned about mold in the walls now. It has a metal skin. How would one go about seeing what’s behind those walls? I am in west central Florida. Does anyone know of someone who would do as good job checking for mold and repairing it? It does have a musty odor. Thank you for your help.
Katewels
Re: Teardrop Repair
Postby tony.latham » Fri Jun 19, 2020 5:29 pm
How old is it? Have you talked to SignaTour?
Without photos, the diagnosis and fix will be difficult. :thinking:
T
Re: Teardrop Repair
Postby saywhatthat » Sun Jun 21, 2020 12:27 pm
tr 015.jpg (748.03 KiB) Viewed 1632 times
The easiest way is get a vibrating saw . cut inside skin small area . plan to cover with something nice .That way you can see . Frist #1 before you do anything do a tap test .Take a quarter tap the wall for changing sounds. At the shop To find hard to find leaks ,Can foam Spray a SMALL bit 30 to 1 expanding rate. will seal and come out any holes IN he picture .Could not even see the holes by just looking
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Re: Teardrop Repair
Postby Katewels » Sun Jun 21, 2020 5:25 pm
Okay thanks for the info. I tried to upload photos but wasn’t able for some reason. What size hole should I start with and if I do find mold and/or damage what would the next step be?
Katewels
Re: Teardrop Repair
Postby saywhatthat » Sun Jun 21, 2020 7:27 pm
did you do a tap test for howl sounds? how are the wall made 3 layers are 2. Have you push ON the wall for a soft spot can you hear any cracking sounds .Where the water stains ?
saywhatthat
Images: 135
Re: Teardrop Repair
Postby dominykass » Sat May 13, 2023 12:20 pm
Hi! Sorry for reviving a necro thread, but I have a similar issue. Besides, it's getting worsen because of the leak mold and mildew appear everywhere. I try to use mold removal sprays, but it's a temporary solution. So, if you know how to fix it, pls let me know
dominykass
Re: Teardrop Repair
Postby tony.latham » Sat May 13, 2023 1:52 pm
dominykass wrote:Hi! Sorry for reviving a necro thread, but I have a similar issue. Besides, it's getting worsen because of the leak mold and mildew appear everywhere. I try to use mold removal sprays, but it's a temporary solution. So, if you know how to fix it, pls let me know
As I mentioned to the original poster, nobody can diagnose without looking at the problems. Photos. :thinking:
Re: Teardrop Repair
Postby Tom&Shelly » Sun May 14, 2023 7:33 am
deanepersson wrote: you might want to consider looking into professional mould removal
That, of course, is for houses, not teardrops. This fellow is a spammer, who has no clue what this forum is about. :stompspam:
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Re: Teardrop Repair
Postby Tom&Shelly » Sun May 14, 2023 9:21 am
BTW, it looks like "dominykass" and "deanepersson" are the same spammer. (If I'm wrong, post a reply, and I will apologize.) :stompspam:
Tom&Shelly
Images: 2282
Re: Teardrop Repair
Postby tony.latham » Sun May 14, 2023 9:42 am
...it looks like "dominykass" and "deanepersson" are the same spammer...
I was thinking the same thing. :thumbdown: :stompspam:
Re: Teardrop Repair
Postby Tom&Shelly » Sun May 14, 2023 10:50 am
Given the nature of the posts, Shelly suggested it might be an Artificial Idiot (AI). :thinking:
Tom&Shelly
Images: 2282
