TimC wrote:I'm assuming you are referring to wall construction. Floor construction is not critical IMO as far as the grade of the skeleton material.
lfhoward wrote:In Home Depot speak, “select” is better quality than “common”. It’s true about the knots and the grain above. I wanted to add, common is often not straight, and tends to bend in weird ways when it gets humid. Building with select boards for your camper’s skeleton will be hassle free but more expensive for sure.
23Sojourney45 wrote:lfhoward wrote:In Home Depot speak, “select” is better quality than “common”. It’s true about the knots and the grain above. I wanted to add, common is often not straight, and tends to bend in weird ways when it gets humid. Building with select boards for your camper’s skeleton will be hassle free but more expensive for sure.
lfhoward, I was wondering if it would bend too. But, would it bend if its sandwich by the 2 plywood floor boards top and bottom? of course this will be after its glued/screwed etc...or will the weight of the two plywood prevent it from bending?
lfhoward wrote:No, once a wall sandwich is all assembled it will be rock solid. I used Kreg pocket hole screws with their jig, plus wood glue, to make the skeleton. Then I used wood glue, a nail gun, and screws to fasten on the exterior plywood.
But if you build part of your skeleton, wait a week before building a little more skeleton... and the humidity changes... You could be dealing with longer pieces that are not as straight as you want. The bending would happen before you build with them and before you lock them down as part of a unified structure.
TimC wrote:Lauren is correct. Keep moving to get the floor fully assembled in a day or two. It will stay put once glued and fastened into a complete unit. Like Lauren, I used Kreg jig and screws to assemble the skeleton prior to completing the sandwich.
Just don't make the stupid mistake I made... description in post #4 in this build journal... https://www.tnttt.com/viewtopic.php?f=50&t=63575&hilit=+sort+of
You certainly can build the floor skeleton with #2 Common with some knots. Plan the assembly out ahead of time and eliminate knots on the edge if you can by turning the lumber around. If you can't avoid lining up a knot on the end where you will be fastening the wall just make a note on a post-it note attached to the frame on the area with the knot and avoid that area for fasteners for the wall.
Good questions. Don't be afraid to ask. That's what we are all here for...
Tim
tony.latham wrote:I used both plywood and pine for the framing of my floor framing.
The three skinny ribs are made from doubled 3/4" plywood set on edge to gain stiffness. The voids are filled with foam board, of course. The top and bottom are skinned with 1/4" subfloor plywood which I find is higher quality than 1/4" AC and a little cheaper. The plywood gussets are temporary to hold the parts in place while the other side is skinned.
Tony, your 2 outside border/frame (the 2 long sides) of your skeleton are 3/4 thick laid flat correct? width of probably 4-6 inches? did you have problem screwing the walls to the 3/4?
Tom&Shelly wrote:I used poplar for the floor, and it worked well. Not much more than #2 pine in cost, and much easier to work with (straighter). Only slightly heavier.
AC plywood is also a good choice. It may be pricey, but you can hollow it out and use it like boards, then the hollowed out pieces can be used for something else. Or, you can cut boards from the 4x8 sheet and use those.
Just a couple more options to consider.
tony.latham wrote:Tony, your 2 outside border/frame (the 2 long sides) of your skeleton are 3/4 thick laid flat correct? width of probably 4-6 inches? did you have problem screwing the walls to the 3/4?
Yes, flat 2x6" pine on the sides.
