What kind of seal does this trailer use for the doors?
Postby *Inside » Mon May 29, 2023 2:18 am
I recently came across the Kuckoo Camper from a german manufacturer. It seems to be extremely well designed and assembly comes together in just a day at their assembly line. Here's a video (in German) of their assembly process: https://www.youtube.com/watch?v=T0RyxjlwU-E
The door construction is extremely interesting
* The exterior of the camper (including the door) is fiber-glassed
* The door has stiffeners
* The door jamb is double thickness plywood (15mm x 2)
* The inner door ring appears to be painted aluminum
* There's some sort of seal mounted to the aluminum door ring (<- this is what I'm trying to figure out)
* There's also some sort of a thin D-seal on the door itself.
Any idea what these might be?
door detail.JPG (37.07 KiB) Viewed 337 times
*Inside
Re: What kind of seal does this trailer use for the doors?
Postby Capebuild » Mon May 29, 2023 8:55 am
Go to the Trimlok website and you'll find the seal you're interested in. It's got a EPDM bulb that's attached to a "U" shaped clip. The clip portion snaps over a lip you'll create from plywood that is part of the trailer's framework.
John
Screenshot 2023-05-29 at 9.43.51 AM Medium 2.jpeg (79.51 KiB) Viewed 309 times
IMG_6356 Medium.jpeg (103.11 KiB) Viewed 309 times
Capebuild
Images: 130
Postby twisted lines » Mon May 29, 2023 9:46 am
The seal to seal is interesting :thumbsup:
Racking up; And Rapin foam
twisted lines
Postby tony.latham » Mon May 29, 2023 11:56 am
It looks like the same Trim-Lok seal I discuss in my book.
Trim-Lok suggests a bulb compression of 30-50% and says that a fully compressed bulb will take a set and not rebound. Dunno about the seal on the door. Must be an inset D-shaped seal.
Postby *Inside » Mon May 29, 2023 12:25 pm
Capebuild wrote:Go to the Trimlok website and you'll find the seal you're interested in. It's got a EPDM bulb that's attached to a "U" shaped clip. The clip portion snaps over a lip you'll create from plywood that is part of the trailer's framework.
John
Ah it is just Trimlok - I don't know what I was thinking as I was staring at it last night. I got a sample piece and it does kinda look like that after it's been squished into shape a lot.
How thick/tall is your inner door lip? Do you know what p/n you used for the trimlok/where you bought it? I'm kicking myself for not buying the standard 26x36 doors back when they were cheap - almost $500/ea now - it seems like it'll be much much cheaper (in money, not time) to build my own :(
Also, looks like the inner lip isn't 1/4" aluminum, but probably 1/4" aluminum composite board (https://www.youtube.com/watch?v=T0RyxjlwU-E&t=1013s)
I'm thinking if I add aluminum L trim to the inside of the door (over the fiberglass) it'll be a nice and flat mating surface to the bulb seal:
door trim detail.JPG (57.77 KiB) Viewed 279 times
Maybe I'm over thinking about the aluminum - you didn't use any, right Tony? Haven't had any leaks?
*Inside
