Marathon trailer sold at homedepot
Postby Offgrider » Wed Jan 25, 2023 11:45 pm
I am planning a new trailer build, has anyone heard any feedback on the 5x8 trailer sold on homedepot.com, the trailer is built by Westbrook trailers. It cost 1099.00
Offgrider
Images: 6
Re: Marathon trailer sold at homedepot
Postby Paintsalot » Thu Jan 26, 2023 10:03 am
Offgrider wrote:I am planning a new trailer build, has anyone heard any feedback on the 5x8 trailer sold on homedepot.com, the trailer is built by Westbrook trailers. It cost 1099.00
This is the same trailer I’ve been asking about that is sold by Tractor Supply. See discussion here: viewtopic.php?f=35&t=75388
It looks like a go to me. The only concern is the axle is a little bit close to the center so you will need to plan to put a bit more weighted items towards the front. I think they’ve only just come out with the trailer recently so there’s not a lot of reviews yet.
You can call the customer service line and they answer the phone which I think is great. It’s made in Canada so I like supporting slightly more local construction. And the 12 inch tires are good, they have a speed rating up to 87 miles an hour, which is much better than the northern tool trailers which only have 45 mph rating on some of them.
My 2 cents.
I may be getting the same trailer, so maybe we can trade notes as we go. I need to sell a few cameras to pay for the trailer first.
Build Journal for the Folding Wooden Camper here: https://www.tnttt.com/viewtopic.php?f=50&t=76513
Paintsalot
Images: 71
Postby Paintsalot » Thu Jan 26, 2023 10:13 am
I don’t think this kind of metal can be welded as easily as steel? Does anyone know?
It combines steel and aluminum I think.
Paintsalot
Images: 71
Postby Squigie » Thu Jan 26, 2023 10:47 am
It requires increased power settings to weld, and requires the same safety precautions as normal galvanizing. You're best off grinding the coating off before welding (which still requires normal galvanized safety precautions).
In other words:
Can be done.
Needs more juice.
Toxic.
Extra work.
Squigie
Postby Paintsalot » Thu Jan 26, 2023 1:34 pm
Squigie wrote:It requires increased power settings to weld, and requires the same safety precautions as normal galvanizing. You're best off grinding the coating off before welding (which still requires normal galvanized safety precautions).
In other words:
Can be done.
Needs more juice.
Toxic.
Extra work.
Thanks for info on this.
Paintsalot
Images: 71
Postby RJ Howell » Thu Jan 26, 2023 3:48 pm
GALVALUME PLUS TM
Galvalume Plus™ is a specialized combination of 55% aluminum, 43.5% zinc and 1.5% silicone topped with a clear acrylic coating.
Ask some real Pro's yet to me it sounds like a diluted aluminum to save on costs and not really sure of the strength benefit.
Now if not re-fabing and staying with the ratings of the tailer, sounds like a decent one!
RJ Howell
Images: 36
Postby KCStudly » Tue Jun 06, 2023 11:10 am
Realize this is an old post, but just to be clear, galvalume is a plating treatment akin to galvanizing; not the alloy that the trailer is built from.
Postby napoleonbot » Fri Jun 09, 2023 2:03 pm
Paintsalot wrote:
Offgrider wrote:And the 12 inch tires are good, they have a speed rating up to 87 miles an hour
Are you sure? many said the tire suck only 70km, etc...
napoleonbot
Postby gudmund » Fri Jun 09, 2023 8:28 pm
and 70 KM = about '40' MPH ........ :thinking:
gudmund
Images: 39
Postby Paintsalot » Fri Jul 21, 2023 11:19 pm
Yes- called Westbrook Trailer- Tires on 5x8 Stirling trailer are rated for 87mph.
Paintsalot
Images: 71
