Pmullen503 wrote:Really looks fantastic.
Remind me, is/will the exterior be painted? With what?
Yes it is and will be. It's not complete as the windows just went in..
Primer became an issue as to what this FG panel likes. BIN (@ $75 a gallon) sticks to everything, but I'm not paying that when I can make my own for a 1/3 of that cost. I used a BM bonding primer and the FG panel said no thank you. I went to Kilz and I'm back on track.
Now painting this stuff is strange in itself. If you hope to allow light to pass, don't paint it. I have not sampled a good way yet because it just seems to burn the paint. Of course since I treated and paint my steel skeleton black, it's absorbing heat.
I need to get back up there and at least paint over where the steel is. Now I know this and would paint it reflective if done again.
If your painting over sealed/insulated walls or roof. Kilz (or make your own shellac base primer) and go for it!
Here's where I hope to experiment with this cooling paint. I basically have a solar box as a roof now. Over our beds I have it insulated, yet the balance of the space has an air gap between exterior & interior. If this cooling paint works, then I already have a cooling panel in play.
Thought off season camping when you turn on the heat before you get up my cause an issue..
Yes, painted and will be. How and where is yet to be determined
