23Sojourney45 wrote:Hey guys, starting to build my trailer slowly. The frame is already built, now working on the tires. I've read a lot from this forum about using regular car tires of the teardrops so that's what I'm doing. Especially, because I like the fact that my TV has the same measurements and comes with a spare which I can use for emergencies. I went to the local salvage "vehicle pick your part" for wheels. I ended up getting 2 wheels that are 15 X 6, they still have the old honda caps on them. They fit on my trailer axle just fine, right hub spacing etc...I went to Walmart today and asked if they could put tires on them, obviously they won't be mounting them on anything since I will be putting them on my trailer. Well,
Walmart basically told me that they couldn't because I needed the tire measurements. I said that
I don't have the tire measurements since they're just the wheels and I gave them the measurements for the wheels. They still insisted that they couldn't do it because it may not fit right etc....and they needed the other measurements to put on the computer etc...So, I asked them "...then how do those car/tire places know what tires to put on when people buy custom rims/wheels?...." the guy had no answer and just kept repeating that
they needed the tire information. I was frustrated and left.
I'm pretty sure Walmart was going through protocol/liability concerns etc...so my dilemma is:
(1) Do I actually go to a tire shop and ask them, maybe are have more knowledge about it?
(2) I was thinking, since my TV wheel measurements are basically the same as the ones I got from the salvage yard (15 x 6) that
I could use the TV tire specs and just give that to Walmart or a tire shop, what do you think? TV is a Honda civic.
(3) Should I just sell the wheels and buy two regular tires?
Any help with would appreciated. Thanks in advance.
23Sojourney45, tires have specific dimensions just as do wheels
IF you intend to use your TV spare as a spare for the TD i might suggest you take the TV spare and see how it actually fits on the trailer
make sure you allow for wall framing and skinning for your tire clearance
the following image is only for example and does not necessarily specify the dimensions and clearance needed for YOUR application and you will have to plug your needs into the image
- 8cd40c2b58857ea175cf93656e877773.jpg (7.8 KiB) Viewed 1451 times
there are several tire sizes that can fit on your 15x6 wheels and the tire dimensions ARE needed by any tire shop in order to meet your needs
this image is somewhat generic but you can go to your TV and replace the numbers in the image w/ the numbers on your vehicle
- 165db949-40ee-4ce8-bbb7-3046118b6a07_1.77c730152e3fe0c89e05f776e87ca2b7.jpeg (41 KiB) Viewed 1451 times
the width of this tire is 215mm
the tire height ratio of 65 in this image means the actual rubber tire results in a tire size w/ a radius equal to 65% of 215mm for a total of 139.75mm (2 x 65% of 215mm for 279.5mm/11" added to 15" would be the assembled tire's diameter of 26"±)
15" auto tires can be purchased from 155mm > 265mm ± wide and the tire store needs to know what size you need/want/think you want
it is sad that the sales person @ wallyworld did not realize you did not understand what he/she was asking about and explain it to you
in all likelihood you need to goto an independent tire shop w/ a more knowledgeable staff and explain what you are trying to do
you will likely get asked more questions that send you home for more measurements
GOOD LUCK W/ YOUR QUEST
sw
