GTS225 wrote:Solar panel to solar/charge control(ler), then to battery, with it's own fuse at battery +. (Don't go through the fuse/terminal panel.)
Master disconnect right at battery plus, then a master fuse right behind it.
You have battery negative (blue) coming off of terminals marked +. You should NOT run battery negative to your fuse panel, unless there's a dedicated ground/negative bus there.
I don't see fuses depicted (schematic symbol) on your drawing, but it looks like a pictorial representation on that terminal block in the center. Am I reading that correctly?
The purple "wires" aren't wires, are they? I think you're using those to represent remotely mounted switches?
Just my quick observations.....Roger
Pmullen503 wrote:It looks like you have 12 fused circuits, if that isn't enough you can double up low amperage circuits like led lights.
Depending on your solar controller, it should have circuitry to handle the the battery/panel charge switch over. Consult the manual that came with it. But either the battery or the controller (usually) should be hooked up the fuse block, not both.
Sometimes, if the controller is designed to handle it, a high amperage device (like a big inverter) can be hooked directly to the battery. Again, consult the manual.
If you plan to have a 120V inverter and shore power as well, it is vastly simpler and safer to run separate shore power and inverter 120V circuits and do not cross connect the neutrals. (I personally, would never ground 120V power to the trailer frame.)
italianub wrote:.
Are you saying don't use 120v circuits connected to the battery, but run a line for them via shore power only? I am likely getting a beefy battery so I was hoping that I could run everything off of that and not rely on being somewhere with shore power.
I am thinking I need a bigger fuse box...
tony.latham wrote:I would add an AiLi meter to monitor the battery, it'll tell you a heck of a lot more than the voltage meter and you won't have to turn all of your power off for 45 minutes to measure the status. I would also reconsider putting that lighted switch panel in the cabin or get rid of it entirely. The lights would drive my wife and me nuts --and they produce a steady drain on the battery.
Also, if you use light fixtures with their own switches, life will be a lot simpler on this project and equally functional.
How does this look?
tony.latham wrote:
The first thing that I noticed was the ground to the chassis. Perhaps that's a good idea since you're running an inverter for 120-volt outlets. We keep an inverter in our tongue box, but I can't recall what we've used it for. It's been a long time since I dug it outta the box. I'll be curious to read other's thoughts on it.
But secondly, don't run the negative of the solar directly to the battery. Run it to the fuse box so it goes through the shunt so you can monitor production from the AiLi meter.
And by the way, we have one dome light in our cabin and don't need two. Teardrop cabins are tiny.![]()
italianub wrote:I would need the inverter to run a cpap machine in the cabin, and things like a coffee pot in the galley.
I would need the inverter to run a cpap machine...
