Of course, we would need another robot dog to take with us hiking....
video on robot dogs
Tom&Shelly wrote:Of course, we would need another robot dog to take with us hiking....![]()
tony.latham wrote:video on robot dogs
You obviously haven't smelled robot dog doo.![]()
bdosborn wrote:Tom&Shelly wrote:Of course, we would need another robot dog to take with us hiking....![]()
I always wanted a pack lama, I wonder how much they poo? You think the neighbors would mind a lama in our backyard?![]()
featherliteCT1 wrote:Lfhoward,
I am glad to see that you posted data showing that your Rpi operates in 28.8F temperatures.
My Rpi connects to a Netgear router where the router serves as a LAN (with no www Internet available). Both devices are located inside my trailer.
When temperatures get below 35F, my Victron Connect app has a hard time connecting to the devices. Below 30F, the connectivity is erratic. Below 20F, the devices are not reliable at all and will not stay connected.
Both devices have published operating specs with a lower temperature range of 30F.
Until you posted your data, I could not tell which device was causing the problem or if both devices were causing the problem.
I now think that the Netgear router has been the limiting device.
Regardless, I solved the problem by putting both devices in my insulated battery box wherein my batteries reside. When ambient temperatures are around 30F, the heat generated internally by the devices in the box keeps the devices at 50F. So far, the devices have been running fine, with temperatures consistently about 20F higher than ambient temperatures.
Last week the ambient lows were about 0F, before I located the devices in the box. This week, since I located the devices in the box, the ambient lows have only been about 30F. So far so good. I am curious what the temperature differential will be in extremely cold ambient temperatures.
Normally, I do not look forward to colder temperatures. But, the science must continue!
so I scooped them up and now I will be building a second 200 watt suitcase.
tony.latham wrote:so I scooped them up and now I will be building a second 200 watt suitcase.
Good grief. You'll put the sun out!! Suck it dry! We're all gonna die!![]()
Sounds like something a Star Wars villain would try to do!
