Starlink Mini Arrived Yesterday
Postby bdosborn » Tue Jul 09, 2024 12:26 pm
I received the Starlink Mini yesterday and I have it connected to my account/working. You need to have an existing Starlink Residential or Roam account to be eligible for the Mini. Data is capped at a puny 50gb/month, with each GB over that costing $1, but it's just $30/month for the plan (Starlink Roam is $150/month for unlimited data). It only takes a minute or two for the terminal to come online after you plug it in and download speeds are pretty respectable at our house:
I tried connecting the supplied power cord directly to 12V and it doesn't work; the cord is too thin and voltage drop is excessive. I made a 12V cigarette adapter plug from a 5' run of 12 AWG wire and it booted right up. FYI, it's a 5.5 x 2.1 mm barrel plug to connect DC power to the terminal.
It fits on the exterior table very nicely but this will only work if the van is parked in the right direction. The terminal likes to be oriented to the north at our house, with a clear view of the sky. The Starlink app helps you align it quickly. It gets surprisingly good download speeds, even partially obstructed on the side of the house:
It does make a quiet buzzing noise but I can't hear it when I'm inside the van. Power fluctuates between 15-25W (I haven't tried it yet with the supplied AC adapter connected to the inverter). I've used this much data in a day just messing around doing speed tests and reading the Facebook. The total time on was probably about an hour.
The data plan definitely isn't a good fit for a RV lifer but it will probably work for an occasional week or two camping, assuming you just check emails/texts and you resist the urge to run Speedtests. Streaming videos will break the bank quick! An old laptop messenger bag makes a good carrying case. I've got 30 days to make up my mind about keeping it but I probably will. I'm gambling that they'll roll out a new data plan in 6 months or so after the novelty wears off....
Images: 806
Re: Starlink Mini Arrived Yesterday
Postby bdosborn » Tue Jul 09, 2024 8:45 pm
Thanks. I'll post an update after I've used it a bit...
Images: 806
Postby Westy » Wed Jul 10, 2024 6:09 am
Although I'm not a fan of Starlink and even less of Musk, I was mightily impressed by the quilt in the background of one of your photos.
My wife is a quilter and I know how much work would have gone into yours.
Well done to your wife.
Westy
Postby bdosborn » Wed Jul 10, 2024 12:15 pm
Thanks! She did that quilt in a week! She's a mighty quilter. :D
Images: 806
Postby bdosborn » Thu Jul 11, 2024 3:11 pm
Starlink released the Mini to the general public today and rolled out new data plans.
You can now choose an unlimited data roaming plan as well as the data capped plan. You can pause the data capped plan so you don't have to pay for it in the months you're not using it. It looks like Starlink threw me a bone as I'm on the $30/mo, 50gb/mo plan as an early adopter.You can bet I'm going to pause it during the winter months.
Images: 806
