Yah....hoo....eee I got it.
The Harbor freight trailer had a Vin number on it and came with the paperwork. I took it in for them to look at it. She did not ask to see the lights was only wanting to see the paper and compare it to the Vin. I told her the inside was not completed and so she listed it as a Utility trailer. I just wanted to get the outside done. Now I can work on the inside. I will not run wires for the battery till after I get back from camping.
I got very confused until I talked with friends, one suggested I call it a hobby, which it is.
I belonged a teardrop forum before this one was started . Mike also belonged to that one until he started this one.
When I first came to the DMV I told them I had a home made camper trailer. The woman gave me papers to fill out.
I found there is a site offering California DMV forms
https://www.dmv.ca.gov/portal/forms/when you enter in the number it will show a PDF that you can fill in on your computer and then print I printed a copy for myself too.
This makes it essayer for them to read. you can save the filled in form or clear it, I chose to clear it.
REG 4017 (Permanent Trailer Identification {PTI} Certification)
REG 343 (Application for Title or Registration)
REG 256. (Statement of facts)
on line it suggested I fill out
REG 5036 (Statement of constuction) which is almost the same as Statement of facts)
Most of these forms are set up for cars with engines and transmissions. in those areas I printed none.
I got really confused when it cam to the section where I needed to explain the facts. A large space for you to tell you story.
At first I told about why it took me so long to build it. But a neighbor suggested I call it a hobby.
So I started the space with Teardrrop Trailers are my hobby. I belong to a Teardrop Trailer forum. You can find my build at
viewtopic.php?f=50&t=54108And the began that I designed and built it. ect.....
I also wrote that I did 98% of the labor and if I could I would say it was free. However if a cost must be state in labor I would pay myself $1.00 and originally I had planed to build it in 3 months. So I added the $480 to the $1303.52 and $284.oo for the frame
The total to build was $2,127.52 to build it .
I was charged $47 in taxes for the trailer.
I came in the next day unable to make a appointment on line, DMV online took me somewhere else???
I came in at 8am with my paperwork, the Vitrifaction of Vehicle completed by the inspector at the back of the building, the Vin paperwork that came with the Harbor Freight trailer frame. Was given a number B 010 and waited about 30 min. to hear and see my number called.
The woman read all my paperwork and entered it all into the DMV computer, and pulled out a Key and gave me a envelope containing my metal PTI Plate.
A note to the wise keep all your receipts and keep them in a dark cool place. Register rec's are heat sensitive and will fade. Keep them where you will always know where to find them.
They did not ask to see them but I was ready. In my case my build lasted 11 years and you could read all of them. I used a contractors clip board which has a cabbie behind it to store the paperwork. All readable.
