Windows Sources
Important Information and Stickies...
(Threads with essential information about building teardrops)
Windows Sources
Postby Dave Nathanson » Thu Aug 22, 2024 5:04 am
Where have you found windows for your TD trailer?
I'm looking for replacement windows that will fit in a 18"x12" hole. The door is 1" plywood plus 1/8" oak inside.
I have the old vintage type with a knob at bottom middle. Knob operates 2 arms to crank window open.
Windows hinge at top.
All that is really broken are some small plastic wheels on the ends of the crank arms. When those break you can't crank the window open, & you can't keep the window shut. I had to duct tape the windows closed.
Alternately if I could get replacements for the arms (probably as a unit with arms & knob?) that would be great as well.
Dave Nathanson
Images: 19
Re: Windows Sources
Postby TimC » Thu Aug 22, 2024 9:01 am
Can you remove the plastic wheels that are broken? If so maybe someone could turn new wooden wheels that would serve the purpose.
If you can provide a photo of those parts it might help.
Tim
Niagara, WI
TimC
Images: 751
Re: Windows Sources
Postby Pmullen503 » Thu Aug 22, 2024 11:03 am
You might be able to get some 3D printed replacements made. Know anyone with a 3D printer?
Pmullen503
Images: 67
Re: Windows Sources
Postby working on it » Thu Aug 22, 2024 12:24 pm
173193172890148599
working on it
Images: 457
Re: Windows Sources
Postby tony.latham » Fri Aug 23, 2024 8:49 pm
You might check this site out and see if there's a file for replacement parts... and then find someone with a 3D printer.
https://www.thingiverse.com/search?q=rv+window&page=1#google_vignette
https://www.thingiverse.com/search?q=camper+window&page=1
Re: Windows Sources
Postby Dave Nathanson » Tue Aug 27, 2024 1:43 pm
I will def check out these ideas.
I do not see what I need at Thingverse nor Amazon (yet?).
It's the little wheels (maybe 1/2" diameter?) at the end of the thin crank arms that slide along the bottom of the window frame.
I'll get a photo for you guys that better shows the problem parts.
Thanks, talk again soon!
:peace:
Dave Nathanson
Images: 19
Re: Windows Sources
Postby RJ Howell » Sun Sep 01, 2024 8:26 am
I do agree with the 3D printer! My cousin uses his to make casts for his forging of metal parts. Amazing what you can do with these!
RJ Howell
Images: 36
Return to Essential Information about building teardrops
