Issue Constructing Big Woody hatch
Postby Pointlookout » Sat Nov 02, 2024 12:26 pm
We are making our trailer from the big woody instructions and hit a huge snag at the stage where you build and attach the hatch. You’re supposed to bend and affix 1/4” hardboard plywood over the curved ribs, which we did, but now the hatch doesn’t fit in the galley as it’s being “pulled” more straight. Without the hardboard attached it fit perfectly. We’re probably going to have to rebuild but want to avoid making the same mistake. Photos attached. Any advice?
https://imgur.com/a/qeXhaLR
Pointlookout
Re: Issue Constructing Big Woody hatch
Postby Pmullen503 » Sat Nov 02, 2024 4:37 pm
If the panel isn't glued down, you could take it off, soak it in water, pre-bend it on some type of fixture and let it thoroughly dry. You'll have to bend it to a smaller radius to account for spring back.
If you have to rebuild, you know about how much it straightened out so over-curve your bows or use one or two layers of 1/8".
Pmullen503
Images: 67
Postby halfdome, Danny » Sat Nov 02, 2024 6:34 pm
I think you need more cross members to control the curvature of the lid.
In the past I’ve used strap clamps to control the lid while the glue dries.
Clamp one end to a flat bench to keep it true and measure opposite corner to corner on both ends to the same measurement.
Even after I built 5 teardrop's on #6 the lid wouldn’t cooperate and I had to make another one.
You’ll need to clamp it a little more than need to avoid spring back.
If you can make a jig to check the lids correct lid curve that would be helpful.
I would recommend skinning and finishing the inside too.
While our teardrop sits in the unheated garage there’s a slight seasonal deflection but adjustable side clamps takes care of the problem.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby tony.latham » Sat Nov 02, 2024 7:32 pm
Dang.
I'm surprised the Wyoming Woody plans call for 1/4" ply––as you well know, it's stiff. I would suggest you use two layers of 1/8" Baltic birch plywood bent with the grain. The stuff likes to bend.
And speaking of which, does your plywood grain run along the curve or left to right? If it follows the curve, that's part of the issue.
Here's a video of my wife and me installing the headliner in teardrop. It's 1/8" Baltic. You can see how bendy the stuff is.
https://youtu.be/rIUUaEKe4mw?si=u8KUWbgGn8Roxv74
Postby Modstock » Fri Nov 08, 2024 3:12 pm
Yes, grain goes across side to side. Easier to bend.
Sent from my SM-A115AP using Tapatalk
Modstock
Postby Pointlookout » Sat Nov 23, 2024 4:03 pm
Dang.
Awesome video! It does look really bendy. Think I can just use 1/8th inch and call it a day? We’re attaching aluminum over it anyway so I’m not really worried about “strength” per se. did you use that same material for the hatch skin?
Pointlookout
Postby tony.latham » Sat Nov 23, 2024 10:30 pm
1/8" Baltic is absolutely strong enough for the outside of a hatch. But don't you need a full 1/4" with the Big Woody? If you do, just use two layers.
Postby Pointlookout » Fri Nov 29, 2024 4:26 pm
So would we glue them together then attach them as one piece you think? Don’t want a repeat of last time! With the 1/4 inch we were considering doing kerf cuts to try and reduce the resistance but I don’t feel like we could do that with 1/8 inch.
Pointlookout
Postby Pmullen503 » Fri Nov 29, 2024 6:28 pm
Get one down and dry and then add the second layer if you need it.
Pmullen503
Images: 67
Postby shanewatson5091 » Tue Feb 04, 2025 1:55 pm
Pointlookout wrote:We are making our trailer from the big woody instructions and hit a huge snag at the stage where you build and attach the hatch. You’re supposed to bend and affix 1/4” hardboard plywood over the curved ribs, which we did, but now the hatch doesn’t fit in the galley as it’s being “pulled” more straight. Without the hardboard attached it fit perfectly. We’re probably going to have to rebuild but want to avoid making the same mistake. Photos attached. Any advice?
:https://imgur.com/a/qeXhaLR
Consider using a more flexible material like 1/8" luan plywood or bendable MDF. These materials are easier to shape and may conform better to the curved ribs.
shanewatson5091
Postby tony.latham » Tue Feb 04, 2025 10:04 pm
I just saw your question. I would lay one layer down, followed by the second layer glued with TB3.
It would be easy-peasy.
Here's a video of my wife and I setting a headliner made from 1/8" Baltic. Note how flexible it is.
https://youtu.be/rIUUaEKe4mw?si=4N6Pdx1YPGfebX6h
Just set it so the grain runs the width of the hatch.
