by KCStudly » Mon Feb 03, 2025 11:30 pm
I'd look at the spec's for PL300. It works with the foam, is pliable like silicon, I'm just not sure if it works with the aluminum. Its intended application is hanging foam board on wall structure before finish paneling is fastened thru the foam.
If it is compatible with aluminum, for your application, I wouldn't notch trowel it. I'd follow the suggested bead size and pattern. I was trying for a structural laminate on my hatch, so I troweled, and that caused trouble with curing; once the air was cut off at the edges the field remained uncured. I solved this problem by making kerf "chimneys" or air ducts in the foam to let air get through to a much larger area, but it was a lot of effort to seal all the ends of the kerfs after the laminate had cured; and that method won't lend itself to your inset 'bay' style installation.
I think the OEM recommended large bead wide zig zag pattern prevents the foam from being pressed intimately with the wall panel, and leaves plenty of air adjacent to the glue line for it to properly cure, even if some of the edges cure up solid earlier than the field. Since you have more than adequate strength in your frame structure, are only looking for the insulation value and enough stabilization to prevent oil canning, I don't think there is any advantage for you to try for a 100/ct bond full lamination. It's not worth the hassle.
I think it was while I was applying the foam core to my hatch that I figured this out, if you want to skim thru my build thread for more details on what I learned using the PL300.
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
