S. Heisley wrote:Looking at your photo gallery, I can't tell if you will have room to stand when your lifting sides are down...?
Thanks for the sketch, fun idea!OP827 wrote:I have just added a schematic sketch in my previous post.
foxontherun wrote:Have you given any thought to windy days when setting up/taking down in your setup? Just curious![]()
Harry
Paintsalot wrote:foxontherun wrote:Have you given any thought to windy days when setting up/taking down in your setup? Just curious![]()
... Open to ideas though. ...
S. Heisley wrote:There is no perfect solution to a handmade lifting roof.
Using a push pull pole from the outside helps eliminate the need for holding the roof with one hand while inserting the peg with the other. You do need to secure the bottom of the pole, though.
S. Heisley wrote:I am so looking forward to seeing this!
OP827 wrote:S. Heisley wrote:I am so looking forward to seeing this!
+1![]()
It was a bit scary how this morning I got the homebuilt trailer video in my YT feed and I did not ask or search YT for this. Not pushing any more ideas, just thought it might be interesting to share.
